e85 fuel needs.
Old Dec 9, 2009 | 09:18 AM
JohnBradley's Avatar
550whp on a DJ for sure.
Old Dec 9, 2009 | 09:27 AM
KTriplett's Avatar
ive run mbc's to 30 psi and never had a problem. idk what you were using, i usually use boost valve but this forge was in the trunk when i bought the shell so i threw it in when i put the motor in. im also going with kelford's...i think. im very indecisive. but ive never heard anyone say e85 is only for bigger turbos and high boost. not sure where you got your info.
Old Dec 9, 2009 | 09:36 AM
Ev0ikon's Avatar
IN-line increase pressure and not flow. Parallel pumps increases flow but not pressure. Just a heads up!
Old Dec 9, 2009 | 09:40 AM
KTriplett's Avatar
thanks ive read that many times now haha. but im just goin with a single intank and 1000cc i shouldnt need much more for the summer.
Old Dec 9, 2009 | 09:47 AM
APM Racing's Avatar
E-85 will make more power on a stock turbo as well as a large one. You can run a lot more timing on E-85 than on pump gas . Granted on a big turbo it will make a lot more difference since you can push over 35psi but there are still a lot of gains to be made with a stock turbo on E-85. The external 255 pump with an in tank feeder pump works good but not as good as an in tank twin. You have a seperate pick up for each pump on a intank twin compared to a single pick up feeding two pumps on the internal/external set up. Your single pump, 1000 cc injectors will be fine for your goals
Old Dec 9, 2009 | 10:04 AM
460hpevo8's Avatar
why would you want to change to e85 with the point of increasing 20-30whp . I bet u cannot feel any different with 20-30whp. And remember , switching to e85 take some times and money , tuning, injectors, pump. Better call your tuner first about switching to e85. I already had my car tune 3 times already, and it is not cheap.
Old Dec 9, 2009 | 10:09 AM
460hpevo8's Avatar
i suggest change everything and check for leak,etc at one time, and go get 1 good tune.
Old Dec 9, 2009 | 10:34 AM
GST Motorsports's Avatar
Originally Posted by 460hpevo8
remember this kt, e85 only worth it if you run high boost (30+) and bigger turbo.
Incorrect.
It is around 20whp just putting E85 in and scaling the injectors. No other tune changes from pump gas, same timing, same AFR, same boost.
After tuning, It isn't odd to see 50whp+ gains on just the stock turbo.
If you search for some of my threads, you will see stock turbo E85 and pump gas overlays, same day, with same mods.
Some examples:
+69whp / +66wtq
+66whp / +46wtq
+66whp / +67wtq
+64whp / +60 wtq
+58whp / +79wtq
+56whp / +52wtq
- Bryan
Old Dec 9, 2009 | 04:13 PM
KTriplett's Avatar
lol even if i only saw a 20-30 whp gain, which im confident itll be more, i would still do it. why, because thats what i like doing. And no, the only thing i need to change is my injectors. And i do realize tunes are expensive. I just said i was new to e85 not to cars. you shouldnt throw hp numbers out anyway when you havnt done it personally. and im after ET's anyway not dyno numbers.
thanks for all the responses guys!
Old Dec 9, 2009 | 04:45 PM
fre's Avatar
fre
I would just get the biggest injectors you can idle decently on so you don't have to replace them in the future. There is no reason to go with a smaller injector unless A) You don't want to shell out the extra 100-200 bucks the larger ones might be or B) You can't get the larger ones to drive well. I don't see that there would be a problem getting the bluemax 1650s to idle and drive well and even the 1850s with the tune box.
I only say this because I just got done going through 3 sets of injectors and now need to upgrade yet again when I build my engine (660s->880s->1150s and now need larger). Just trying to save you some cash.
As far as fuel pumps go, I am currently supporting up to 550whp with an in tank walbro 255 and an inline bosche 044. I will try for 600+ when I build my engine and upgrade to 1850cc injectors.
Old Dec 9, 2009 | 04:52 PM
KTriplett's Avatar
im just going with 1000's at this time. doesnt bother me much to upgrade when i have to its all getting torn apart next winter anyway. And because im trying to get the best MPG i can while keeping the DC to 60-80%. no, MPG is not a priority of mine, obviously, but ill take it what i can.
Old Dec 9, 2009 | 10:30 PM
460hpevo8's Avatar
please read my mods mr. ktriplett
Old Dec 10, 2009 | 10:36 PM
KTriplett's Avatar
Eve OH
E85 / Ethanol
Dec 1, 2015 03:02 PM
norcalSRTrida
50
Oct 15, 2010 08:12 AM
GsXiNuOFF
14
Apr 26, 2008 08:31 PM
TrinaBabe
Nov 29, 2005 10:28 AM
evo_dan
25
Jan 20, 2003 03:51 PM
