IAC Valve question
Old Dec 30, 2009 | 11:56 AM
ch53avitech's Avatar
IAC Valve question
I have a spare IAC that I took off my car due to idling issues (the IAC wasn't the problem). Does anyone have a diagram for the IAC plug so I can test it? I want to make sure it's a good IAC valve before I sell it. I guess I just need to know what pins I need to hook a power and a ground to.
Thanks
Old Dec 30, 2009 | 03:23 PM
Ttmft
Old Dec 30, 2009 | 08:25 PM
No one knows?
Old Dec 30, 2009 | 08:28 PM
SilverShadow03's Avatar
I was told if you disconnect it from the TB and leave the wires/harness on it and put the key to the on position (maybe crank it over??) you should hear/see the shaft move/turn if it is still good.
Give that a shot...
**confirm this before attempting...**
Old Dec 30, 2009 | 09:31 PM
Thank you. I was leaning more towards just somehow giving it power via 12v battery. The valve has 6 pins but as far as I know it should only need power and a ground to actuate.
I'm aware of the suggestion you mentioned though. Thanks for the input.
Old Dec 31, 2009 | 11:23 AM
More help please.
Old Dec 31, 2009 | 02:37 PM
Evoryder's Avatar
hope this helps
Old Dec 31, 2009 | 03:57 PM
Thank you Evoryder, I'll try this out tomorrow tomorrow when there's more light and after my hangover wears off.
Thanks again.
Old Jan 4, 2010 | 02:59 PM
Evoryder's Avatar
^ Any luck?
Old Feb 13, 2010 | 07:39 AM
jbenosa's Avatar
yes, any luck? i think my IAC is bad ('03 Evo8) and may need to replace mine.
Old Feb 13, 2010 | 11:10 AM
Evotech8's Avatar
^ test it first...
I bought a new one but it didn't solve my idle stumble problem. Wasted $300-
shottas9
May 25, 2016 04:57 PM
GSXPimp
Feb 17, 2016 06:15 AM
luisderoux
Dec 15, 2015 09:40 AM
Tobra
Lancer Troubleshooting
Feb 20, 2015 05:24 PM
BUDZ69
Aug 6, 2009 09:03 AM
