Car sounds different after changing to 15W-50 M1 Synthetic...
Old Jan 4, 2010 | 04:32 AM
rd122481's Avatar
Old Jan 4, 2010 | 04:56 AM
grillpt's Avatar
Why the switch to the heavier oil?
I would think it would be louder esp in the temps your seeing right now, 15w-50 has go to be thick as molasses at 30degrees F.
Old Jan 4, 2010 | 05:02 AM
rd122481's Avatar
The car is going on the dyno today & I wanted to change the oil first, it was nearing that time. I went with a thicker oil because I will be installing a Shearer T3 kit w/ a HTA3582 as soon as I get back home & I thought I would get extra protection from a slightly thicker oil.
Old Jan 4, 2010 | 05:15 AM
grillpt's Avatar
So is the kit on the car now?
I could see using that weight in the heat of the summer, it might be a little too much for January though...
Old Jan 4, 2010 | 05:20 AM
TIBOevo's Avatar
you would go with thicker oil durring the summer and thinner oil durring the winter. if the weather is close to freezing i would go with 5w30.
Old Jan 4, 2010 | 05:31 AM
rd122481's Avatar
Old Jan 4, 2010 | 06:37 AM
tscompusa2's Avatar
Originally Posted by rd122481
The kit is not on the car now. I'll be going to the dyno today because I'm having clutch issues & it is better to test these on a dyno than the street. The kit will go on a.s.a.p though.
Will I harm anything if I leave this oil in? I have to drive on the highway (70mph) for 1.5 hours to get to the shop, but when I get back home, I'll park the car until the weather heats up a bit...Weather.com says the weather will be back up to high 70's in about a week.
no.
Old Jan 4, 2010 | 07:11 AM
Gary@MellonRacing's Avatar
u should here ticking on cold , and as it starts to heat up , it should go away
Last edited by Gary@MellonRacing; Jan 4, 2010 at 07:12 AM. Reason: .................
Old Jan 4, 2010 | 07:20 AM
metalsaber's Avatar
He is down in Florida. Though I guess they have some cold temps down there right now. Still seems like a bit thick for the Winter even in Florida.
Old Jan 4, 2010 | 09:00 AM
SWOLN's Avatar
Hey man, PM me...
Old Jan 4, 2010 | 09:25 AM
apagan01's Avatar
in all honnesty you have chosen the wrong oil weight for the cold snap we have here in florida this week.
you should be using a 0W30 or 5W30 even a 10W30 would be fine just heat it up a little.
15W50 is like trying to sip on panckake syrup throug a coffe straw, you are hurting your engine more than what you are helping it, if you were running high boost 35+ with big turbo and built engine with some hot fuel i would say ok to use (still not needed though) but where your car is sitting now no need for the 50.
the tap is because the pump is suffering trying to pump that thick *** cold oil through the galleys.
My engine is a completely stock Mivec longblock with FP4R cams. I changed my oil this morning using Mobil 1 Synthetic 15W-50. I usually use 10W-30. Now the car sounds different. I feel like I can hear the valvetrain more...but it is weird... it is only @ certain RPM & it is not constant... Am I just being nervous?
Only sometimes @ idle I feel like I can hear the valvetrain tapping louder than I'm normally accustomed to. But it's only sometimes & not the majority of the time. Then I stand still & rev & hold it @ 4K and it sounds like everything is running in tip-top shape...
I hope I didn't mess something up...
I live in FL where the temps are usually in the 80's. Today they are in the high 30's. (I don't know if that matters at all.)
Anyone have experience with this?
Old Jan 4, 2010 | 09:29 AM
evovin's Avatar
2qt 5w30
2qt 10w30
for me
Old Jan 4, 2010 | 09:30 AM
IDRINKV8'S's Avatar
That's why i stick too 0w-30or 10w-30 if it's not broken don't fix it.........
Old Jan 4, 2010 | 10:00 AM
SWOLN's Avatar
+1 film stregth, not heavier oils. rd122481, come to the meet, and I'll talk to you about it tonight.
RallySport9
Jul 12, 2012 12:52 PM
PKEVO8
Mar 13, 2007 06:45 PM
Racer24x
Lancer Engine Tech
Jan 25, 2007 06:10 PM
kilgoja
Nov 21, 2006 07:30 PM
Chewie4299
Jul 17, 2006 12:50 PM
