Ryu's hunting for 9's on the Stock Block
Keep us updated on the build...I am assuming you will still be using your judge intake manifold. Will you still be using a judge ported stock exhaust manifold or try out a tubular?? And Judge is porting the turbo too correct? Post some pics of the ported turbo if you don't mind...
Correct me if i'm wrong but isn't the black just a bigger compressor wheel on the same turbine?
Have you logged your back pressures? I think with the red you are already pushing quite a huge back pressures and just upgrading the compressor wheel will make the situation even worse. So this would spell bad news for the stock block, increased egts knocks and ..
Would it surprise anyone to learn that the back pressure on the Black flowing 60lb/min is actually LOWER than the back pressure on a Red flowing 60lb/min?
Robert Young at FP
Robert Young at FP
I find that quote to be about right. The reason I say that is that, it will take the Black less work to produce that amount of air in comparison to the Red. What I mean by this is say the red needs to spin at 150,000 rpm to produce 60 lb of air. The Black, since it has a bigger compressor wheel, can possibly do it at around 125,000. These are not actual number just theorizing. Since there is less rotations per minute that also equates to less back pressure.
Good luck man, I don't think anyone is worried that you won't hit 9's!
^you mean over his 93oct+meth? not talking about the 110oct+meth right?
haha fail
haha fail
