Ryu's hunting for 9's on the Stock Block
Old Jan 22, 2010 | 06:45 PM
  #91
RyuEvoIX's Avatar
My Judge Racing ported ported FP Black turbo arrived today. The port work is absolutely second to none. She should flow like a champ! Thanks Judge!
Next step is to have the hotside and the exhaust manifold ceramic coated.
Old Jan 22, 2010 | 06:53 PM
  #92
Pal215's Avatar
I have a feeling as soon as you bolt this monster in your going to see 9's easy! FP BLACK FTW!
Old Jan 22, 2010 | 07:12 PM
  #93
TTP Engineering's Avatar
Looks nice.
Old Jan 22, 2010 | 07:24 PM
  #94
BLKCarbonEVO's Avatar
Looks nice ryu
Old Jan 22, 2010 | 08:25 PM
  #95
Cyloc's Avatar
just for comparison......Here is a picture of RYU's black hot side what it was received.
Old Jan 23, 2010 | 12:00 AM
  #96
EvolutinIX's Avatar
Originally Posted by RyuEvoIX
Yes they are.
I expect to not have too. The plan is to do it with good ole 93oct in the tank w/ meth injection.
That is crazy! What meth injection kit are you running??
Old Jan 23, 2010 | 12:48 AM
  #97
gt30revolXmr's Avatar
WOW!! That port work looks absolutely amazing. GL with your quest to go 9's I really want to see 9's in the out come for this looks like a great set up
Old Jan 23, 2010 | 04:29 AM
  #98
Cyloc's Avatar
aquamist HFS-1
Old Jan 23, 2010 | 07:19 AM
  #99
RyuEvoIX's Avatar
Originally Posted by Cyloc
aquamist HFS-1
Thanks Ant.
A complete mod list will be posted once the car is complete.
Old Jan 23, 2010 | 07:40 AM
  #100
silver9mr's Avatar
very nice so when will you start us off with a ttp dyno vid to hold us off till you hit the track
Old Jan 23, 2010 | 08:08 AM
  #101
RyuEvoIX's Avatar
Some time in the next two weeks. The hotside and exhaust manifod are going in for ceramic coating today. Then once I install the turbo mid this week the car will be taken to Alex Roque, one of the best fabricators in Florida, to transfer my custom o2 housing solution from paper to engine bay.
Old Jan 23, 2010 | 08:28 AM
  #102
impavidoevo5's Avatar
goodluck on breaking into the 9's but sell that turbo asap!!!! i havnt seen any REALLY impressive proof about this black, its just overkill in my oppinion its to much stuffed into to small of a housing your just gonna generate alot of extra heat. y i DOUBT youll ever go 9's on pump and meth with out knocking a rod right out of that block. MAYBE if you can supresse the knock with c-16 you might go 10.0-9.99 with perfect driving and a little weight loss.
Old Jan 23, 2010 | 09:21 AM
  #103
penthouse's Avatar
good luck Ryuix, show us some timeslip when u hit 9s.
Old Jan 23, 2010 | 12:34 PM
  #104
norcalSRTrida's Avatar
have the 02 plumb into the exhaust WAY down stream at an easy 30-45* angle...no more.
we had a local test an 02 recirc back to back w/ an 02 dump.
the recirculation plumbed into the exhaust like 3ft down stream...so no cause for turbulence.
he gained 45hp going dump.
this was on an SRT-4 fwiw, but the concept is none the less, still the same.
he hated the dump noise as well...his solution? he bought an inline straight through motorcycle muffler and had it welded in to make the dump quite.
effective, and most power potential...something you should think about.
Old Jan 23, 2010 | 02:12 PM
  #105
RyuEvoIX's Avatar
My plan is to certainly route the wastegate tube as far down the exhaust stream as possible. Unfortunately 3 feet seems a bit unrealistic on an Evo in comparison to an SRT4. It's quite tight in the oil pan area as it is with just a 3inch downpipe, especially on an ACD equipped Evo. I have a few ideas and I expect the results to be quite favorable. Thank you for your input.
