!!!!JE pistons Pins?
Old Jan 6, 2010 | 02:28 PM
Dragking2189's Avatar
I bought a set of JE psitons for my 2.0L build . I'm planing to make 750-800 but I wonder if the wrist pins that came with the piston set will be good enough. If not what do you guys recommend
Old Jan 6, 2010 | 09:54 PM
SeanC's Avatar
Upgrade to at least a .170" wall pin. I would recommend using the .210" wall 9310 pin for that power level.
Old Jan 6, 2010 | 10:42 PM
JohnBradley's Avatar
We run .250 in all of our JE sets. I wouldn't do anything less than the .225 that Wiseco offers as the HD. Those I know from personal experience are good to over 1000whp.
Old Jan 8, 2010 | 06:19 AM
EvoPower81's Avatar
What hp are the stock Wiseco's good for safely?
Old Jan 8, 2010 | 09:46 AM
By stock Wiseco you mean non HD non 0.225 wall pins? I cannot say, I havent run them.
Old Jan 8, 2010 | 10:55 AM
Teal2nnr's Avatar
Not trying to take this off topic, but I just bought a set of CP Pistions....should I be upgrading the pins?? I'm looking for pretty big numbers so i don't want this to be a weak point.....
Old Jan 9, 2010 | 01:39 AM
EvoPower81's Avatar
The problem I have is with the 4g64 build the HDs are 9.7:1 while the stock are 9.1-9.3: 1 compression. I would buy the HDs for the extra safety but the 9.7:1 is a little high for 91 octane where I live. I want to safely make 550-600 whp meth injected. What do you think ?
Old Jan 9, 2010 | 09:35 AM
konstantinosIX's Avatar
Are these JE pistons BR spec or not?
Old Jan 9, 2010 | 09:43 AM
No, I bought the pistons straight from Je, I will call them this week to see what they recommend
Old Jan 9, 2010 | 09:25 PM
There are many manufacturers that have off the shelf pistons in lower compression. All of them will engineer a lower compression piston for 40-50 a set typically since thats the only thing changing. JE has 8.5:1 on the shelf and I am pretty sure there is an HD 4G64 that is also 9:1 or lower.
I have only seen 2 CPs recently, one of the GSC 2.2 pistons and one was for a turbo 700R Yamaha quad. The Evo piston had a heavier pin in and the one in the Raptor was a little smallish in my opinion.
When you order pins from anyone making the pistons you can order upgraded at that time and I am assuming that if their customer service is worth a darn they will sell them after the fact or exchange them for the price difference and freight.
hutch959
23
Sep 12, 2016 05:17 PM
foxbat
Sep 17, 2015 07:31 AM
evo-qtr
22
Apr 19, 2012 12:28 AM
gldenchld
Oct 12, 2004 02:28 PM
JVlancer
Lancer Engine Tech
13
Oct 26, 2003 10:39 AM
