problem with shifting (hard) Please help
Old Jan 15, 2010 | 03:14 PM
  #31
apagan01's Avatar
Originally Posted by rcheung
You used SVG for the the tranny or tcase? I have only used MTG which is the recommended fluid for the tranny.
sever gear for the TC and rear diff, its the diaqeen replacement
MTG GL4 is for tranny
Old Jan 15, 2010 | 03:19 PM
  #32
apagan01's Avatar
I am personally not a fan of bg fluid. I change my tranny fluid every 5000 miles. I have used bg syncroshift, Redline MT 90 and amsoil MTG. With bg, the drain plug would be covered in metal bits to the point where you could not even see the magnet. With Redline MT90 , there was much less metal flakes and the magnet can be seen. With amsoil there would be so little metal bits on the magnet that you wouldn't even need to wipe it off when changing the fluid. I stuck with Amsoil for that reason. You can see how well it protects the gears.
as for the AMSOIL why there are little to almost none metal prticles compared to many other fluids because simply is a synthetic and breaks down less and less under high temps.
its so bizare how some point the finger at the oil so quick and they dont look at the mechanical posibilities that is causing the notchy feeling in the gears, there are so many places to look at before one should even look at the oil for problems, MTG GL4 is a direct replacement for OEM Diaqueen.
Old Jan 15, 2010 | 04:50 PM
  #33
Evoryder's Avatar
1. re grease underhood bushings(change to brass if you haven't already, makes a nice difference when shifting)
2. Change transmission fluid. I have tried all the brand names and I am running Amsoil, best results so far.
3. If it's still a little notchy then your clutch could be on it's way out or something similar.
Old Jan 15, 2010 | 04:51 PM
  #34
Evoryder's Avatar
Old Jan 16, 2010 | 08:38 PM
  #35
jamevo8's Avatar
I went through this for 6 mos it was my exedy clutch that was burned out I had it rebuilt and all is good now
Old Jan 18, 2010 | 09:23 AM
  #36
boostedscooby 5's Avatar
so am i looking to replace the clutch. I have not tried to replace the transmission fluid with nothing but oemv yet . I m thinking in replacing it with some after market fluid. which would you guys recommend to use. Today is a little warmer that it has been awhile. It shift a little better but not like when i first got the car. Thank for the advice
Old Feb 11, 2010 | 12:20 PM
  #37
i will be changing the transmission fluid again . The car wont shift when cold at all, I have to wait 20 minutes before it will let me shift into 1 st gear. Am really disappointed . Been having nothing but trouble since i got the evo.
Old Feb 11, 2010 | 12:30 PM
  #38
detroit pistins's Avatar
do u have underhood hood bushings, or a short throw shifter?
sorry to hear about ur experience dude, hope u get things figured out.
Old Feb 11, 2010 | 01:50 PM
  #39
Kevin.'s Avatar
Amsoil isn't very good for syncros unless it is warmed up. It is probably great racing fluid for trannies.
Old Feb 11, 2010 | 02:10 PM
  #40
mr. happy's Avatar
OEM Fluid FTW
level100
Sep 18, 2014 12:16 PM
yesevo
24
Feb 28, 2013 04:05 AM
TaKectrLANCER
Lancer Troubleshooting
11
Aug 9, 2010 12:53 AM
xninjaix
Lancer Tranny/Drivetrain Tech
Sep 7, 2009 06:14 PM
EVOIIIM3
Mar 27, 2006 03:05 PM
