Car is coming out of gear
Old Feb 12, 2010 | 06:56 PM
turbotalawd's Avatar
Check fluid, check the ball detents, or it could be the synchro going bad. Does it grind anytime while you try to shift into 5th?
Old Feb 12, 2010 | 07:46 PM
EvoVIII :D's Avatar
Mine usually does. I got to the point thinking the gear itself was shot, being the teeth worn down
Old Feb 12, 2010 | 07:49 PM
n2oiroc's Avatar
popping out of gear is usually bent shifter forks or a shifter out of adjustment.
Old Feb 12, 2010 | 10:15 PM
Evonrails's Avatar
worn syncro in 5th. Sounds like the hub is worn for sure. How many miles are on the car? This is a common issue with SE-R's
Old Feb 13, 2010 | 01:02 AM
Sounds like the synchro to me if it only grinds while going into 5th.
Old Feb 13, 2010 | 05:43 AM
EvoVIII :D's Avatar
63k
playmajohn
22
Jun 13, 2017 11:47 AM
weeeeeeeeee
May 17, 2016 01:21 PM
Llew
Oct 14, 2015 03:14 PM
Jrod@Buschur
Apr 21, 2010 08:01 AM
powerjjang
20
Mar 13, 2008 11:21 AM
