wastegate overboosting
Old Jan 22, 2010 | 08:34 AM
joel(PA)'s Avatar
I am having an issue on my car where I have the gate directly connected to the turbo, and sometimes the car overboosts the 15lb spring. Sometimes it will come up to 20-21psi.
Could a boost leak cause this? I have my suspicions the car has a large boost leak, from how it feels under boost....
Old Jan 22, 2010 | 09:22 AM
evokid511's Avatar
i have the same prob on my tial 38mm, dont know why though... i had a 15lb spring and it would never open below 20lbs
Old Jan 22, 2010 | 09:39 AM
joel(PA)'s Avatar
I'm on a buschur cast kit with 44mm
Old Jan 22, 2010 | 10:19 AM
MR Turco's Avatar
sounds like boost creep. is it an external or internal WG? Also, it could be pressure difference depending on where your boost source and PSI monitoring source are in the system.
Old Jan 22, 2010 | 11:22 AM
TiALSport's Avatar
is it only doing it in the cold? or year round?
Old Jan 22, 2010 | 11:24 AM
20gmr's Avatar
you say sometimes, does that mean the car goes to the 15psi gate pressure correctly some of the time? How sure are you that it has a 15psi spring in it?
Old Jan 29, 2010 | 01:09 AM
joel(PA)'s Avatar
it is really cold right now... i havent ran the car yet in the warmer weather with this setup.
the tial 44mm has the 15lb spring
Old Jan 29, 2010 | 08:45 AM
TiALSport's Avatar
what size ID line are you running from the turbo to the gate?
PearlWhiteX
May 9, 2016 08:05 PM
TS Dork
Nov 28, 2013 07:34 PM
ogrenator
Cobb AccessPORT
Mar 25, 2013 06:59 PM
Wayne99gsr
Northwest Region
16
May 26, 2011 08:25 PM
mikiblueeyes
11
Mar 13, 2006 09:55 PM
