O2 Dump Issues
Old Jan 22, 2010 | 01:53 PM
broddey's Avatar
O2 Dump Issues
My EPM O2 dump has exhaust leaking out of it at idle (smokes on startup out of the dump tube). This is causing my AFR at cruise to be all over the place, and my idle isn't great.
Could this be the result of my FP actuator being tightened down too much? I had my tuner loosen it to remove my boost creep issue, but it still leaks and I'm tempted to switch back to my stock O2 housing.
This leads me to believe that exhaust is flowing around a slightly opened waste gate at idle. How do I fix this?
Old Jan 23, 2010 | 08:35 AM
Liqquid's Avatar
you need SOME preload on the flapper, undo the pin and see if the arm just slides off the flapper lever, if it's that loose you may need to tighten it up some. You should have to at least pull a little bit to get the arm on there
And did that actually get rid of the boost creep anyways???
Old Jan 23, 2010 | 08:43 AM
MitsuJDM's Avatar
Do you have the correct gasket? Otherwise it's a wastegate issue.
Old Jan 23, 2010 | 10:24 AM
EvolutinIX's Avatar
Plus one, this is the right track.
Old Jan 23, 2010 | 10:56 AM
broddey's Avatar
Thanks for your response. Loosening the preload did help significantly with the boost creep. My previous tuner (not TTP) cranked the wga all the way down because it wasn't putting out the numbers it should have. TTP loosened the wga, fiddled with the tune, and made more power (still not where it should be).
I'll fiddle with it and see if I can get a little preload on it like you say.
I HAD the correct gasket on there originally, but the other shop (who will remain anonymous) might not have put the gasket back on there. I will check that as well.
Old Jan 23, 2010 | 11:07 AM
High_PSI's Avatar
Don't use a gasket, I didn't, no leaks....
Old Jan 23, 2010 | 11:20 AM
silver9mr's Avatar
yea make sure you do not have a gasket on. the epm o2 dump is supposed to not have one installed
funyun
24
Jun 26, 2019 09:29 AM
jk_evo8
May 7, 2016 08:44 PM
blackblaze427
15
Jul 23, 2013 02:21 PM
Evolessfornow
23
Jun 3, 2011 10:57 AM
dank420
Mar 19, 2011 04:26 PM
