HELP car shut Down and lights diming
Old Jan 26, 2010 | 07:46 PM
badbishnc's Avatar
ok so heres whats been going on, for the past few days my cd player has been reseting the presets for the radio, and then tonight i was out riding around and my headlights cut off and then so did my cd player for a second and come back on. then a little ways down the road the radio cut off again, so i had to go by my work and while i was talking i had the driver door open and the interior lights were flickering with my cams at idle, so i left there and on the way back to my house my cluster lights and headlights all cut off and come right back on and my antilock brakes light came on and stayed on for a sec then cut off, and so im just about to my house when the car cuts off and all the lights go out, the lights came back on tho, so i coast into my driveway and cut the switch off. and i tried to crank it back up and it fired right back up with out any strain on the battery? what do u think is causing this?? i was thinking alternator but why would the car crank right back up? any help is greatly appreciated!
Old Jan 26, 2010 | 07:48 PM
varner88's Avatar
either bad ground or like you said your alternator is going out.
Old Jan 26, 2010 | 07:50 PM
badbishnc's Avatar
there is some corrosion on the battery too, but i hope its nothing too serious
Old Jan 26, 2010 | 08:20 PM
binh's Avatar
hint: check the thread about water coming in through the grommet under the driver dash
Old Jan 26, 2010 | 09:04 PM
badbishnc's Avatar
ok so i just got home and tried to crank it once again, on the first try all i got was a click and the interior light went out, on the second try it fired up, so i unplugged the negative side off the battery and it stayed running, so i guess battery is out...so i turned my lights and radio on and the voltmeter dropped from 14.6 down to 13.5 and went back up, but when i flash my high beams the car stumbles and acts like its gonna cut off and the cel lit for a sec but went back out once the car builds the idle back up. so im guessing the alternator is on its way out??
Old Jan 27, 2010 | 08:35 AM
badbishnc's Avatar
ok well i took it to autozone today and both the battery and alternator checked out good? any ideas? i gotta get this thing fixed asap!
Old Jan 27, 2010 | 08:54 AM
binh's Avatar
do you park your car outside? does it see rain?
if so, i already gave you your answer above
Old Jan 27, 2010 | 08:58 AM
binh's Avatar
since you're a newb i'll do your work for you:
https://www.evolutionm.net/forums/in...s-how-fix.html
Old Jan 27, 2010 | 09:00 AM
evolvd276's Avatar
bad connection some where youre not getting enough juice to run the electronics hopfully a bad battery connection or altenator
Old Jan 27, 2010 | 09:17 AM
badbishnc's Avatar
could be what it is? i couldnt find the thread last night? but thank you and i will check on this as well! and yes it sets in the rain and we had a heck of a rain storm the other night!
Old Jan 27, 2010 | 10:10 AM
06redrocket's Avatar
haha idk if this helps but i installed an after market intake on my srt-4 and the same exact thing was happeneing to me and i couldnt figure it out. anyway long story short i found out the metal intake was rubbing up against the posiive side of the battery . Maybe your upper intercooler pipe is doing the same. Just a thought .
Old Jan 27, 2010 | 10:17 AM
maperformance's Avatar
I seen this same problem with another car in NC. We replaced the battery and Alternator and all his problems were gone. Had me puzzled too.
strife
85
May 12, 2025 04:08 PM
Sir_Lancer_Lots
Lancer Troubleshooting
Nov 7, 2016 09:47 PM
nmilsaps
Apr 2, 2012 05:31 AM
13laqout
Oct 10, 2011 10:13 AM
Ozdriver
May 15, 2009 10:28 PM
