About Shortblocks
Old Jan 28, 2010 | 05:13 PM
5LEEPERISAH23I's Avatar
About Shortblocks
Well i am soon going to be around 450-500whp.. Im on a Stock motor and it is my Daily Driver.. With that being said im kind of scared of blowing my motor...
I know this is a noob question but im going to ask it anyways.. "If you blow your stock motor will you need a new core no matter what."
Old Jan 28, 2010 | 05:16 PM
ak47po's Avatar
Depends on what happens when you blow your motor.Throw a rod out the side of the block then yes you need a new block.There are many ways to blow a motor.Going lean and frying a piston you should be able to reuse the block.Every situation is different.
Old Jan 28, 2010 | 05:21 PM
Erik@MIL.SPEC's Avatar
Yes, short of "windowing" a block or scuffing the cylinder walls so bad they're unrepairable, you can typically reuse the block.
Old Jan 28, 2010 | 05:38 PM
thanks alot guys.. so it really depend on how you blown it... and when you blow it im guessing turn off the car ASAP
Old Jan 28, 2010 | 05:44 PM
wizzo 8's Avatar
Yes but it will probably be too late anyways
Old Jan 28, 2010 | 06:03 PM
awd2gen's Avatar
Yeah it all depends. i fried a piston and was able to use my block. just had to go .020 over bore. But on the other hand i have seen big holes in blocks from rod hardware failure and the rod shooting through it.
Old Jan 28, 2010 | 10:30 PM
BenJ's Avatar
like others have said, it all depends on the extent of the damage. If you put a hole in a piston or fry the rings it can be a pretty simple fix all things considered, but if a rod lets go, which they are more likely to do at the higher hp/tq levels, you will more then likely be adding a window to your block. Best case scenario you can bore your block .40 over or .20 over or whatever, but worst case scenario....start saving for a bottom end now. On a side note, some insurance companies are really good/nice about paying for these types of mishaps, which is a plus.
Old Jan 29, 2010 | 04:59 AM
So if a rod goes I need a shortblock plus a core... And how to I go about my motor with my insurace company About my motor.. Like what do I say?
Old Jan 29, 2010 | 05:05 AM
MR Turco's Avatar
what insurance company is going to pay for you modifying and destroying your motor? Don't ever assume insurance will pay. There are alot of evos running 400-500whp on stock block, there are also a lot of evos that have blown up their motors running 400-500whp. It is a risk that you should be prepared for the worse.
If you can't afford to do it right the first time, how can you afford to do it twice? No matter how you swing it, it is ALWAYS going to be more expensive to fix a destroyed motor versus a working one.
Old Jan 29, 2010 | 05:58 AM
very true.. i just dont wanna build IF i dont have to... i wanted to keep a stock block for a year then build next year.. but will have money if it goess
Old Jan 29, 2010 | 06:36 AM
MR Turco's Avatar
if you want to wait, then turn down the boost and limp around on a safer level. up to you really.
Old Jan 29, 2010 | 08:37 AM
JesseB's Avatar
I agree take it safe if its a concern
Old Jan 29, 2010 | 08:41 AM
BenJ's Avatar
I've personally seen a check cut for a blown block by Mercury Insurance and while I agree that you shouldnt count on it, perhaps you can get lucky like that one guy with Mercury did, just saying. Now back on topic.
Old Jan 29, 2010 | 09:02 AM
JohnBradley's Avatar
The only time I have seen insurance companies pay for a destroyed motor it was shop keepers insurance covering it. Keep in mind if you were able to do something like that for a private party you raise everyones rates. If you cant afford to pay for it and want someone else to, dont put yourself in the situation to begin with.
Oiling problems can destroy the crank and thrust and make an otherwise usable block nothing more than a boat anchor. A badly blown headgasket can jet the top of the block and head and make them junk.
cliffs- dont blow the motor up, just build it before it fails.
bbrowne777
Jan 7, 2017 02:42 PM
greenman
Dec 17, 2014 10:36 AM
greenman
Dec 9, 2014 07:20 AM
Meevo
51
Dec 3, 2009 08:04 AM
