Kelford 272 and stock turbo
Old Mar 8, 2010 | 11:43 AM
  #31
dambikeracer's Avatar
Originally Posted by MICLOIV
you guys think kelford 280's are overkill on a ported stock 8 turbo?
Yes! Very mush so!
Old Mar 8, 2010 | 12:14 PM
  #32
tdubbz's Avatar
I'd go with the GSC S1 268/268 grind over the Kelford 264/264. S1 should make a bit more power while retaining the stock valvetrain. I don't mind spending the $$$ to do it right with the 272's but I don't think those cams match the stock turbo powerband...and I don't plan on switching turbos maybe to a EVO IX but doubtful.
Originally Posted by dambikeracer
Kelford 264's with the stock turbo. The 272 make a lot of power over 7k RPM's, you wont be doing that with the stock turbo. If you look at the AMS shootout, they tested every cam with a 500+WHP GT35R setup. It's not apples to apples.
I have Kelfords 272 and did not make hardly any WHP with the stock 9 turbo. Although, I really fill them working at 6000-8500 RPM's with the FP Red.
Old Mar 8, 2010 | 02:13 PM
  #33
slvrr's Avatar
Go with the Kelford's for sure you will not be disappointed!! The S2 is a nice cam as well, just not as beefy as the Kelfords
Old Mar 8, 2010 | 03:56 PM
  #34
evodom1's Avatar
Can somebody explain me about gains in power on stock turbo with anything more than stock cams? As far as i understand the turbo's gona run out of normal compressor map - there is not enough stock turbo to work with 272/11 cams!
Old May 5, 2010 | 02:05 AM
  #35
GregM's Avatar
Would love to see a Kelford 264 and 272 comparison on stock turbo
Old May 10, 2010 | 10:39 AM
  #36
tdubbz's Avatar
got the Kelfords installed on the stock turbo and I absolutely love them! What a difference throughout the powerband and not losing anypower up top.
Old May 10, 2010 | 12:58 PM
  #37
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I have a brand new set for sale too if you know anyone else interested in getting a set of those cams.
Old May 10, 2010 | 03:25 PM
  #38
[I.R.A.]_FBi's Avatar
havent read the whole thread but there is a thread around here called "big cam little turbo"
https://www.evolutionm.net/forums/ev...ms+small+turbo
Old May 10, 2010 | 04:22 PM
  #39
bbyevo8u's Avatar
why would you loose any power up top?
Old May 10, 2010 | 09:48 PM
  #40
Blowstock06's Avatar
thats my next mod :]
Old May 11, 2010 | 09:09 AM
  #41
tdubbz's Avatar
What I meant was the stock turbo typically is out of breath at higher rpms and the power curve will downward slope. Especially on the 8 turbo
740 Turbo Brick
Nov 8, 2015 12:24 PM
scothu
24
Sep 28, 2014 06:22 PM
RickU
14
Sep 20, 2013 11:50 AM
EVO'D8
Jul 18, 2012 05:16 PM
Kracka
30
Dec 19, 2008 06:06 PM
