cold start
Old Feb 3, 2010 | 03:57 AM
bbyevo8u's Avatar
cold start
when i start my car in the morning it runs at like 300rpm's with the oil light on for a few seconds then jumps right up to idle "1000rpms"
is this a problem, what could it be?
Old Feb 3, 2010 | 06:48 AM
krisiun's Avatar
When did it start, how long has it been doing this and have you changed anything recently?
Old Feb 3, 2010 | 10:13 AM
bbyevo8u's Avatar
It just started doing it!
I didn't change anything yet!
Does this happen to anyone else?
Old Feb 3, 2010 | 04:04 PM
project_skyline's Avatar
Could be dying IAC motor, try cleaning it.
Old Feb 3, 2010 | 07:55 PM
bbyevo8u's Avatar
^^ whats a iac motor?
Old Feb 3, 2010 | 10:40 PM
idle air control motor, its what helps with your car being able to idle. Its on the throttle body below the inlet, its a black cone sorta shaped sensor with a plug on it with 3 small screws.
Old Feb 4, 2010 | 12:45 AM
EvoKnievel's Avatar
Yep try the IAC....sounds liek that could be the problem.
Old Feb 4, 2010 | 03:55 AM
bbyevo8u's Avatar
ok ill check that out.....Thanks
Old Feb 4, 2010 | 07:45 AM
DIDYSIS's Avatar
Might be running really rich or lean right off the bat, cold can change allot with starting. But check the other also.
Old Feb 4, 2010 | 01:02 PM
bbyevo8u's Avatar
My fuel pump has been whinning real bad maybe it's the pump that's causing this?
Jdubya555
Lancer Troubleshooting
Mar 30, 2017 08:04 PM
pitmac
Oct 18, 2016 07:46 PM
cjpty
Oct 25, 2015 04:26 PM
oneofakindtrini
21
Jul 23, 2009 08:55 AM
chopzilla
Jan 26, 2005 08:45 AM
