AWD Motorsports Round #2 of Testing with FP BLACK on the " Bastard " EVO!!!!
wasnt the bbk running 30psi? so its running 4psi more
Look's like the turbo is at nearly maximum output. 34psi with the extra displacement should equate to the around the same Lb/min output as around 39-40psi on a 2.0L. What rpm are you seeing peak boost?
true but id imagine a HIGH compression 2.4 would make the torque up above 600 with the same boost
The BBK which is a much smaller turbo in comparison to the FP Black made equal whp/wtq. It stands to reason the Black would make 30-40wtq less then whp even given the displacement. The torque is obviously much higher then it would be on a 2.0L so regardless it's nothing to scoff at.
You are the only one here trying to discuss peak number comparison between different dynos. That topic is not even in question. Why you even attempted to bring something petty like that up in an attempt to prove a point in a peak whp to peak wtq discussion of this setup on AWD's dynojet is beyond me....
. Make sure you get good video with the GoPRO this time!
