AWD Motorsports Round #2 of Testing with FP BLACK on the " Bastard " EVO!!!!
Old Feb 6, 2010 | 02:59 PM
  #61
AWD Motorsports's Avatar
Originally Posted by RSMike
how did you get the boost to come in so much faster on the 42psi run?
Cam timing or have you changed something in the setup?
We swapped boost controllers and played with Wastegate Actuator.. Along with tuning..
Mike
Old Feb 6, 2010 | 03:00 PM
  #62
Originally Posted by crispeed
No cam timing changes.
They asked for my help in getting the boost up and I granted their wishes.
I was logging the wastegate and figured out what the problem was. Too bad we did not discover this earlier because it would have helped with the earlier results.
When we get stumped you always have the answer.. I HATE YOU.. JK
Old Feb 6, 2010 | 03:03 PM
  #63
EvoPower81's Avatar
This has totally confirmed my decision on which turbo for my 2.4 setup. Great results guys!!!
Old Feb 6, 2010 | 03:09 PM
  #64
RyuEvoIX's Avatar
Originally Posted by freshevo8
Which means your FP Red shaft speed was way over its maximum also, correct?
No. I am on a factory 2.0L. A red at 40psi peak boost on a 2.0L will have a slower shaft speed then a red at 40psi peak on a 2.4L. There is a larger displacement to pressurize so it will take a greater demand from the turbo to push the extra air needed to pressurize the extra room. Based on 9sec9's testing on the Red with shaft speed vs psi I was probably just at the maximum limit, if not slightly over.
Old Feb 6, 2010 | 03:11 PM
  #65
scorke's Avatar
The fact of the matter is neither of those turbos at 40 psi are going to last long.
Scorke
Old Feb 6, 2010 | 03:37 PM
  #66
Scorke
Thats why we were chosen by FP to do Testing.. Robert knows we will do testing with the product at it limits and give them valuable feedback..
Mike
Old Feb 6, 2010 | 03:40 PM
  #67
freshevo8's Avatar
I just don't get why you are worried about shaft speed and longevity @42psi on the Black? You didn't seem worried when you ran 43.5psi on the RED and i'm almost certain whether it be a 2.0 or 2.4l it isn't healthy for that turbo anyway.
Wouldn't someone at FP be able to answer this question your interested in? Since when is the word of 9sec9 scripture anyway? AWD didn't seem to be testing shaft speed on the BBK also as most performance shops are going for maximum performance most of the time. I'm sure if you bought this turbo on a 2.0 or 2.4l you wouldn't be worried about shaft speed @42psi by lookin at the accomplishments in your sig or how long it lasts at that amount of boost.
Old Feb 6, 2010 | 03:49 PM
  #68
scorke's Avatar
Mike
There you go
When shops try new things we all benefit as consumers because they push products beyond their intended boundaries of use, so that we don't bolt on a turbo, run 2 psi over the recommended limit and blow it up!!!
Scorke
Old Feb 6, 2010 | 03:53 PM
  #69
freshevo8's Avatar
Hadn't FP already done the testing on the Black on a dyno also?
  #70
Hes just trying to point out anything to drag the thread down.. He has been the only person in 70 posts on this thread and 128 posts on our BBK record thread stirring the pot.. Ryu was never so interested when we were breaking records on Haltech and AEM.. maybe the stock ECU stuff is hitting home now.. IDK
I can tell you, i will take a stock motor and push it next if thats what it takes to put icing on the cake..
Mike
Old Feb 6, 2010 | 03:57 PM
  #71
freshevo8's Avatar
Sorry, i'll stop highjacking this thread. Nice results again Mike and can't wait till I receive mine. Better yet, can't wait to see what it runs in the 1/4. Any guess?
Old Feb 6, 2010 | 03:59 PM
  #72
Zeus's Avatar
Crap stops here... don't whine for what you rep here after... General warning...
Old Feb 6, 2010 | 04:00 PM
  #73
Its cool Man.. I appreciate outsiders looking in commenting on my threads.. I know i am not the only person who sees the same things..
I hate to speculate what the Black will run but i can tell you our Goal is 9.4.. Its not often we fall short of our Goals.. It may not be on 1st time out but i am going to get this FP black to run 9.4's on Stock Ecu..
The Stock Ecu ET record is 9.9 & MPH 143.. Those are the 2 immediate Goals with this car.. Then we go for overall FP Black Record on Stock Ecu..
Mike
Old Feb 6, 2010 | 04:02 PM
  #74
Zeus, Thanks for chiming in before the thread gets trashed.. Its going to be a long thread as i would have guessed so I am trying to keep it clean..
Mike
Old Feb 6, 2010 | 04:03 PM
  #75
localtoys73's Avatar
hey mike,
what fuel pump set up is on this car? and these were 1200cc injectors?
my black will be here in a week or so, good to see its turning out to be a nice turbo
