How much HP from Porting FP Red
Old Feb 22, 2010 | 11:25 PM
  #91
BLKCarbonEVO's Avatar
Originally Posted by yahu
^which BOV do you have? I have some flutter in certain situations but that is due to my TiAL spring being too much for my vacuum.
Ya but that is BOV flutter... A lot different that compressor surge. I also thought you were out for the night.
Mikey
Old Feb 22, 2010 | 11:26 PM
  #92
tscompusa2's Avatar
Well this is something that only happens in 4th gear at like 2000rpm if you hit it, its because the turbo is trying to flow so much air, and the motor is choking on it, its not the bov.
I use a forge type rs it seems to hold nice. i pressure tested the car up to 48psi already with it, and no leaks. when i go SD i will get a tial as well, imo they are the best bov's on the market.
Old Feb 22, 2010 | 11:31 PM
  #93
^ Look into the turbosmart Race Port BOV. That is what I have and It is made after the Tial 50mm but I like it a lot better. I also think it looks better
Mikey
  #94
tscompusa2's Avatar
i did notice i was spinning 2nd gear like it used to spin 1st, so i guess you can say it feels more torque'er.. ( is that even a word? lol) the VDR showed different though, but my timing maps were all ****ed up! so who knows what it does now. i was only tuned for 12* up top and the rest was all 8's and 7's in peak tq, which is a dangerous tune.... for now im going to tune it myself and than probably drive it up to buschur and see what happens with stock maf. i know its on the last bar of the maf, but it should be ok.
Old Feb 22, 2010 | 11:34 PM
  #95
tscompusa2's Avatar
Mikey
alright ill look into that one. is that one a little less stiffer than the tial or something?
Old Feb 22, 2010 | 11:35 PM
  #96
Old Feb 22, 2010 | 11:38 PM
  #97
tscompusa2's Avatar
ya it looks good, looks like a tial. what makes it better though? it opens more than the stiffer tials?
Old Feb 22, 2010 | 11:39 PM
  #98
I would def go SD. I don't know that it is really worth much hp but the drivability is tremendously increased
No the spring is the same as the Tial I believe. It has two springs in it. It is not suppose to flutter because the lighter spring is for low boost just driving around town and the second heavier spring in for high boost. So ya there are two springs inside. One inside of another. I didn't take it apart but I'm pretty sure that is what Turbosmart told me
Mikey
Old Feb 22, 2010 | 11:40 PM
  #99
I'm just bias and like it more. I think they are pretty identical honestly. I have not swapped a tial on my car just to see the difference...
Mikey
Old Feb 22, 2010 | 11:41 PM
  #100
yahu's Avatar
Mikey
Shhh, don't tell anyone. The forums are too exciting right now with this conversation and the JesseB one going on.
BTW - the stiffness on the TiAL is adjustable and is based on your vacuum at idle. I didn't realize I could choose a different spring when I ordered it and I basically have 2 sizes too stiff for my vacuum level.
Old Feb 22, 2010 | 11:43 PM
  #101
tscompusa2's Avatar
wow thats awesome!...... i will definitely put that on my list for my new upper piping setup. Im going SD, im just trying to see what it does first on maf. i pulled the screen out atleast, so if the turbo gets hungry it has nothing to eat.
Old Feb 22, 2010 | 11:46 PM
  #102
tscompusa2's Avatar
checking that thread lol.
Old Feb 22, 2010 | 11:47 PM
  #103
Ya the bs going on in the JesseB thread is priceless. Hell I'm in bed with my laptop. This time it is evom and not ****
Ya the turbo tends to get hungry some time. When you look into the UICP look into ETS Short Route UICP. I love mine and it is stainless steel so its "indestructible"
Mikey
Old Feb 22, 2010 | 11:58 PM
  #104
tscompusa2's Avatar
Mikey
will do. ive always liked ETS. my perrin fmic may need to be changed to a buschur fmic as well. it seems the mods never end? its a endless path of blowing $
Old Feb 23, 2010 | 12:02 AM
  #105
I would get the ETS 3.8 or 4.5" Garrett Core! I think they are the best on the market!
Mikey
