ACD fluid lowering when hot?
Old Feb 21, 2010 | 07:25 PM
Deathevn's Avatar
My question is in regards to the ACD fluid reservior level lowering when pushing the car on the track. The car is a 05 Evo 8 MR, stock turbo and e85. Pushing 400whp and 389 ft-lbs. Most of the time I run my HPDEs about 3/4, until I find a quick car to follow. Well, I found a fixed up C5 to follow. After a couple of laps of pushing it too keep up, all my ACD lights came on.
I pulled in, and sure enough, my ACD fluid is about 1 inch below the minimum line. So let the car idle for about five minutes, go do my download for 10-15 minutes, and when I come back my ACD fluid is back up to the max line where I had filled it up the night before.
Anyone know what the cause of this might be? I would think as the fluid gets hotter the level would go up. The car isn't leaking either, nothing on the garage floor after sitting there for a week. It also returned to the original level after sitting for 20 minutes or so.
SUMMARY***
ACD fluid start out at max line.
Push the car hard for 15 minutes, ACD fluid goes below the min cause all ACD lights to come on.
Car sits for 20 minutes, level returns to max line.
Causes?
Should I just overfill the reservior the little?
Thanks
Robert
Old Feb 21, 2010 | 07:43 PM
4cdndctn's Avatar
The ACD fluid level drops as it gets hot. I have not had my lights come on but I'm not driving in Phoenix heat either... I am surprised after only 15min this happened.
Old Feb 21, 2010 | 07:53 PM
chaotichoax's Avatar
totally normal...fluid goes down as the car is driven
Old Feb 21, 2010 | 07:56 PM
Deathevn's Avatar
This was on Firebird Main, which has a 1/2 mile straight. I've been doing HPDEs for a little over a year, and this has never happened on Phoenix International Raceway, where we do most of our events. This is only my second time doing Firebird Main, but wasn't on E85 last time.
If everyone else is having the same issue with no problems, then guess there isn't too much to worry about. There is still a couple inches before the reservior goes empty, and it has only got that low once.
Old Feb 21, 2010 | 07:59 PM
ray3328's Avatar
Yeah it's normal man, nothing to worry about.
Old Feb 21, 2010 | 08:00 PM
Q8_EVO's Avatar
thats weird.. i was following him all the way in a 20 min session, averaging same speed and stress on the car .. my ACD fluid went down to Min. while his was noticeably way below Minimum
Hope its normal, and see u in 3 weeks Rob
Old Feb 21, 2010 | 08:06 PM
EvolutinIX's Avatar
Originally Posted by ray3328
yeah it's normal man, nothing to worry about.
+1
honda-guy
14
Dec 28, 2015 04:49 AM
HAHAV8
Feb 21, 2012 10:36 AM
Ryuartz
15
Feb 13, 2012 03:46 PM
HaVoC187
May 15, 2011 02:13 AM
TurboTimah
24
Apr 12, 2007 05:07 PM
