Oil Pump...Which one?
Old Feb 24, 2010 | 08:56 AM
05ah8james's Avatar
I'm in the process of collecting all the odds and ends to complete my build. I have a Buschur Destroked 2.1 4G64, and I'm ordering a new oil pump for it. My question is: Do I use the 4G64 Oil Pump or the 4G63 Oil Pump? I've looked at detailed pics of each and I can not see a visible difference in the two, however the difference in cost is significant.
I know the 4G64 Pump would work, but does the 4G63 provide more oil pressure?
Any input would be helpful! Thanks in Advanced for the help!
Old Feb 24, 2010 | 10:37 AM
SeanC's Avatar
Not sure if there is a difference, but I used the EVO front cover assembly.
Old Feb 24, 2010 | 12:15 PM
20gmr's Avatar
Should be the same, Only variation i have ever seen in 4g oil pumps is between 6 and 7 bolt, one has straight cut gears and one has helical cut gears for noise reduction. both supposedly flow the same, what are you using for balance shaft?
Old Feb 24, 2010 | 02:04 PM
05ah8james's Avatar
Balance Shafts are deleted. So both are the same? I looked up costs for the parts from mitsu. The 4G64 pump is only $78 while the Evo 4G63 is $215.
Old Feb 24, 2010 | 05:26 PM
JohnBradley's Avatar
2000+ 4G64 and 4G63 use the same part number- MD366260
Old Feb 24, 2010 | 06:51 PM
05ah8james's Avatar
Thank you!!
Old Feb 24, 2010 | 06:59 PM
05ah8james's Avatar
Thank you!!
Old Feb 24, 2010 | 09:53 PM
MRfabolous's Avatar
wow you can get a 4g64 oil pump for 78 bucks where at i was just on mitsubishi parts.com and they wanted 172.. thanks for you help.
benIX
Nov 26, 2016 07:58 AM
benIX
Oct 6, 2016 03:48 PM
foxbat
16
Aug 4, 2016 07:45 PM
Ichigo0Soul
May 23, 2016 09:02 AM
evoboy2006
Feb 11, 2013 10:12 AM
