INLINE RACING -2.0l MOTOR BUILD w/ PICS
Old Oct 12, 2010 | 09:20 PM
  #121
TakaseEVOIXSE's Avatar
Originally Posted by 95630706
Are those TEs 18x9.5 +22? 255/265? Nicely done!
yes they are! thanks!
Old Oct 13, 2010 | 02:55 PM
  #122
here's a shot of the surge tank and the 2 bosch 044 pumps. These are parallel, but there is a walbro 255 still intank making this setup series as well. The walbro feeds the surge tank. I havent connected all of the lines yet as i'm waiting for the guys to put the clutch/tranny back in so everything can be re-installed for proper placement in the engine bay.
I had some inquiries on the fuel setup so here's the latest pic.
INLINE RACING -2.0l MOTOR BUILD w/ PICS-fuelsetup2.jpeg
-Tom
Old Oct 15, 2010 | 08:15 AM
  #123
CO_VR4's Avatar
That's funny that you have the Weldon pump sticker on your surge tank, when you're using Bosch 044s. One weldon would take the place of them both.
Old Oct 15, 2010 | 11:12 AM
  #124
95630706's Avatar
Whenever I see te's that just "look right" it always seems to be that off set...
Old Oct 16, 2010 | 09:38 AM
  #125
mikesrex's Avatar
what is the reasoning in using a walbro in-tank feeding the surge tank which is drained by a pair of bosch pumps? I'm not sure if thats a good idea, but I'm still thinking about what good and bad outcomes could possibly exist with a setup like this.
Old Oct 16, 2010 | 10:44 AM
  #126
n2oiroc's Avatar
It will work great. Its not a new idea.
Old Oct 18, 2010 | 10:38 AM
  #127
thanks for pointing out the obvious. The weldon sticker is from my fuel pressure regulator. Its a weldon unit.
Old Oct 18, 2010 | 10:41 AM
  #128
thanks. And yes, its not a "new" idea. So it does work. There are two shops we know of that use this on domestic cars and also some hondas.
Old Oct 18, 2010 | 10:43 AM
  #129
ToxicFab's Avatar
very nice, coming along great tom
Old Oct 18, 2010 | 10:47 AM
  #130
anyways, I finished the rest of the lines for the fuel setup over the weekend. My friend who owns the shop also finished putting in my longer gears in the transmission as well as installing the Tilton carbon twin disc. We'll have it buttoned back up again this week. It was a hassle taking it all apart again for these changes, but well worth the delays. Once the transmission is back on and the motor repositioned back to where it needs to be, I'll finish the -10 breather lines from the valve cover and the 3rd coolant line to the catch tank. Finish up some minor wiring and hopefully start her up real soon. I completed a base map on the AEM EMS for start up w/ the ID2000s so hopefully everything will go smoothly, LOL.
-Tom
Old Oct 18, 2010 | 10:50 AM
  #131
hey Collin! this must be your new workplace eh? nice!
I head you did some badass work on Gonz's manifold
Old Oct 18, 2010 | 11:11 AM
  #132
ToxicFab's Avatar
you got it bro, here is a link to a few pics of how his car is coming along.
https://www.evolutionm.net/forums/we...on-thread.html
Old Oct 20, 2010 | 07:07 AM
  #133
mikesrex's Avatar
I understand it may work more or less on other setups, but there is just something bothering me about using pumps set up like this.
Old Oct 20, 2010 | 04:21 PM
  #134
Well, if it helps you sleep at night Mike, the guys at Hennessey brought over a built RSX w/ the EXACT same fuel setup. In tank Walbro 255lph pump feeding a surge tank, then to Dual Bosch 044s in parallel, to Injector Dynamics injectors. Identical to my setup. Ran flawlessly on the dyno By the way, TurboXS even sells a pre-made kit that is virtually the same. I just realized this after we made mine, lol.
Anyways, the transmission w/ the longer 3rd/4th gearing has been installed. I just need to put everything back in the engine bay (eg. catch tank, radiator, IC pipes, FMIC etc) so i can measure out the breather lines and then finish the downpipe.
-Tom
Old Oct 20, 2010 | 05:50 PM
  #135
C.Gonzalez's Avatar
Good to see the car coming along Tom. Hopefully we can both get kicked out of HRP the same day! ILR FTW!
