Stalls when clutch is disengaged..
Old Aug 11, 2010 | 09:24 PM
  #46
D-VO's Avatar
Bump again! Did you guys get this resolved? I'm having the same problem, but because I'm using a push type clutch I'm thinking I have crank walk. I had my father push down on the clutch for me so I could watch the crank pulley, but man its hard to tell if its moving. Is there any tools that you guys know of to test this?
Old Aug 11, 2010 | 10:59 PM
  #47
RSMike's Avatar
crowbar/screw driver and dial gauge
Old Aug 12, 2010 | 12:17 AM
  #48
D-VO's Avatar
Anything that doesnt involve a dial guage? ie; force a stick behind the crank pulley then press the clutch to see if it falls out...?
Old Aug 12, 2010 | 03:02 AM
  #49
RSMike's Avatar
factory limits is 0.4mm movement, standard value 0.05-0.25mm.
I'd say a dial gauge is necessary
Old Aug 21, 2010 | 10:17 AM
  #50
D-VO's Avatar
I'm getting no play at all. Probably because of the ACL thrust bearings that I forgot I had.
CoastEvo: Did you ever resolve this problem? I'm starting to think its the clutch master cylinder. It makes sense since when the brake/clutch fluid starts to heat up it causes more pressure in the system. If the seal is bad, the brake/clutch fluid forces its way past the seal in the clutch master cylinder then causes a backpeddling effect into the resevior. What do you guys think?
Old Nov 23, 2010 | 07:01 PM
  #51
D-VO's Avatar
Hello again! So, my problem has gotten so bad that I decided to buy a digital caliper from Advanced Auto Parts. I checked the movement and I'm at 1.04mm of play. Does anyone know or have any experience with having to rebuild the engine at a certain degree of movement?
Old Nov 25, 2010 | 06:23 AM
  #52
C130flyer's Avatar
If you push the clutch pedal in and it comes back up on its own, you DO NOT have crankwalk.
Old Nov 25, 2010 | 09:47 AM
  #53
dastallion951's Avatar
well since uve been tryin to diagnose this issue, ok lets walk through the basics, you already did a boost leak test....hopefully u put enough pressure into the system check.
other questions:
1) did you check for an exhaust leak? that can cause a lean condition?
2) did you check pre turbo for an air leak? that can cause a lean condition?
3) did you check for a vacuum leak like someone stated??
4) if you check all those n see if those pan out, get your hands on a fuel pressure gauge and see if you can monitor your fuel pressure to the rail?
5)have you replaced your spark plugs?
thats all i got so far do some more testin then report back.
good luck
Old Dec 8, 2010 | 11:23 AM
  #54
Spec-Ops1's Avatar
I am more concerned with the clutch stalling issue. Any word on that ? This is an interesting case.
Old Dec 9, 2010 | 11:11 PM
  #55
D-VO's Avatar
If the crank moves more than .25mm when you press the clutch YOU HAVE CRANK WALK. My clutch engagement point drops when I shift fast and will not re-adjust until I rev the engine, but it does come up.
Old Jan 22, 2011 | 09:26 PM
  #56
D-VO's Avatar
Just in case anyone cares; this is what I found: Name:  IMAG0176.jpg
The old thrust washers are on top, and the new ones are on the bottom. I was suprised how easy the thrust washers came out by removing the cradle only. I thought I'd be able to replace the thrust washers only, but it turns out the crankshaft bearings are bad now because of the movement.
I wonder though, if I were to check it earlier when the problem first started happening, would I have been able to save the other bearings? Does anyone know?
Old Feb 5, 2011 | 01:37 PM
  #57
phemes's Avatar
Looks like a good reason to disconnect the clutch switch to me.....putting pressure on that thrust while cranking with no oil is not good. That's what i did after my rebuild.
Old Feb 5, 2011 | 01:47 PM
  #58
mikeyj's Avatar
Ive heard about loose engine mounts causing idle issues because of vibration issues. But i guess you would have mentioned vibration. It may be the alternator or battery? Try those.
Old Feb 7, 2011 | 08:48 PM
  #59
D-VO's Avatar
Yeah I did this for a little while, but realized NLTS or (can't remember) Launch control doesn't work.
Old Feb 8, 2011 | 05:57 AM
  #60
20gmr's Avatar
That's odd. In my car I unplugged the top switch and the car start fine clutchless, and nlts still works great. I'm still using tephra v5 for reference
