Input Shaft Seal
Input Shaft Seal
So im almost positive my input shaft seal is leaking...i have transmission fluid coming out the bottom hole in the trans...its a very small amount but none the less a leak. How hard is it to change out the input shaft seal?? Whats the part number and what other tools do i need or can i put the seal in with my hands? If anyone knows or has done this before please help me...i don't want to pay to have it done if its easy. I hate problems like this. something so small and you have to drop the whole tranny just for a seal.
I don't know about our Evos but I had a 1990 fwd-t DSM that had an input shaft seal leak and I had to pull the tranny and have a shop replace the seal. At least on the FWD mitsu trans, the case had to be split and the input shaft seal accessed from the inside. The Evo tranny, however, may be different (hopefully)!
Good luck!
-Franc
Good luck!
-Franc
I've never done this so maybe I should be quiet. But, the service manual shows the seal being installed from the outside. You remove the stamping the TO bearing rides on and there it is.
I've read that the tranny likes to take out the bearing that is behind the seal. If there is wobble in the shaft then the seal is not going to hold. So maybe that is why they split the case - to replace the bearing which does go in from the inside.
BTW, my experience is that you need a driver anytime you are pounding a seal into aluminum. In my case this always involves finding a pipe nipple of the correct size and grinding it flat on one end with a pipe cap screwed onto the other.
aviseevuoptical
Feb 28, 2016 12:24 PM
Western_man
Oct 24, 2010 11:14 PM
