rod bearings
Old Mar 6, 2010 | 05:05 PM
travail's Avatar
rod bearings
Well a little info on why I need new ones. I heard this noise it sounded weird under load so I had to look in to it and I found out that my rod bearings were going out it looks like the metal was flaking off (I had a bad oil pump and I didn't know it) so I am looking in to getting new ones what kind should I look in to.
Old Mar 6, 2010 | 05:54 PM
boosted2x2's Avatar
i use cosworth or acl
Old Mar 13, 2010 | 10:23 AM
THUB's Avatar
I have ACL in my car, Clevite77 has been making bearings since before any of us were born, cosworth is by no means bad, there's more that aren't coming to mind I wouldn't mind in my engine, You really can't go wrong with any of them as long as you buy the right ones. Just check your clearances and make sure the bearing journals aren't scratched up at all.
Old Mar 13, 2010 | 10:28 AM
WHTEVO's Avatar
I have used the Clevite77 in many builds and haven't had any issues. Good luck.
Aaron
Old Mar 29, 2010 | 08:13 AM
maxims4g63's Avatar
personally installing acl's right now, but clevite or cosworth are just as good.
Old Apr 9, 2010 | 07:06 PM
motion3131's Avatar
i had rod bearing issues i just went with Acl race bearings!
Old Apr 12, 2010 | 12:17 PM
20gmr's Avatar
A lot of OEM bearings are actually made by ACL, I reccomend either ACK or OEM, clevite doesn't have quite as good quality control, from what I hear anyway.
Old Apr 12, 2010 | 01:24 PM
Ev0ikon's Avatar
ACL race bearings.
Good thing you caught it early!
Old Apr 12, 2010 | 11:55 PM
motion3131's Avatar
yea, rod knock sucks. I just had slowboy do a build for me! 2.0l shortblock longrod! Well see results in a couple weeks!
Old Apr 15, 2010 | 12:00 AM
BLKCarbonEVO's Avatar
Acl, acl, acl :d
Old Apr 15, 2010 | 12:23 AM
Lucas English's Avatar
That part number is std bearings but it looks like it has an undersize marking on it. You have a turned crank? If so that is the source of the issue, oil pump helps it along of course but turned crank=fail.
Old Apr 15, 2010 | 12:27 AM
Now you are up late Luke! I'm excited to see how my car preforms! Get that puppy finished. lol
Mikey
travail
Jul 15, 2010 09:58 AM
travail
11
Jan 29, 2010 05:33 AM
travail
18
Jan 27, 2010 03:35 PM
travail
Nov 15, 2009 05:51 PM
