boosting low
Old Mar 6, 2010 | 06:58 PM
MitsuEvo1's Avatar
boosting low
So, I did a search and couldn't really find a real answer, so I'll see if anyone would be able to answer it here..
I have a Evo IX and it's stock. I just recently installed the Defi BF boost guage and went out to test what my Evo is pushing.. I am reading that Evo's out the door is pushing around 19PSI..? With that, I am no where near that. My spike/peak is at 14PSI and drops to 13PSI.. Anyone know if this is normal or did I wire it wrong? Everything seems to be fine but 13PSI is pretty low!! Should I check for anything or am I just over-reacting? Any info would be great!
Old Mar 6, 2010 | 08:18 PM
sparky's Avatar
I don't know if all new stock Evo's are set at 19 PSI when they leave the factory. I do know that my particular Evo, which is a 2004 RS, came with boost set at 14 PSI from the factory... so it can happen. There are variances.
Old Mar 6, 2010 | 08:19 PM
slabbadabba's Avatar
i think your just over reacting
Old Mar 6, 2010 | 08:24 PM
FedEvo8's Avatar
Definitely do a boost leak test. Also the IX's are known to leak at the throttle body shaft seals.
Old Mar 6, 2010 | 08:30 PM
buchnerj's Avatar
Agreed. Boost leak test will tell you where the leak is in the induction/charging system. If worse to worse since you have a boost gauge now, get a boost controller and start tuning for a little higher boost.
Try and find your leak first. If you don't find a leak then something is a little fishy as IX's should come stick with close to 20psi of boost.
Old Mar 6, 2010 | 09:21 PM
MitsuEvo1's Avatar
Hmm.. Yea, I guess I will try doing the boost leak test. It definitely seems that I am boosting to low.. Running 13PSI as oppose to 20PSI is a big difference, I don't know why there are so many mixed answers.. I guess I'll try doing the test tomorrow.
Old Mar 6, 2010 | 09:28 PM
EvoHung's Avatar
+1000 on the boost leak test. Check your hoses where your boost gauge lines goes to and from for leaks.
Old Mar 7, 2010 | 12:53 AM
RNSpeed's Avatar
When I bought my Evo and installed a Boost gauge it was reading 14-15 psi. After reading and reading and the help of the forum members I finally fix the problems.
  • 1rst I did a leak test and found a bad diverter, (change it) but still the gauge didn't past 15psi.
  • The major problem was that the cat converter was clogged, had to took it out and cut the inside with a pry bar. Then the car will boost all the way up to 25psi.
  • Found that 25psi wasn't safe, so I bought a MBC and set it to 22psi.
Hope it helps.
Old Mar 7, 2010 | 05:05 AM
grillpt's Avatar
From the factory is should be running 19.5 tapering too 16.5lbs. I had a problem with mine where my WG actuator diaphram when bad. I would boost all over the place but always lower that it should have (sometimes 17 dropping 13, others 15 tappering to 12),
I would do the leak test, if that doesn't turn anything up, look into the actuator.
Good Luck.
Old Mar 7, 2010 | 08:45 AM
italianevo88's Avatar
if you dont have a MBC you should deff. get one anyway, so at least you can adjust once you figure out if its leaking or not
Old Mar 7, 2010 | 09:24 AM
MitsuEvo1's Avatar
Thanks for the responses fellas. I will take note of all that was mentioned. I do have a Greddy RS BOV but other than that, it is stock. I will go out today and check my lines.. Hopefully, it is what I am thinking it is and nothing more.
Old Mar 8, 2010 | 10:02 PM
JFuego777's Avatar
+1 on the plugged cat---just made a test pipe to replace it today
Old Mar 17, 2010 | 01:30 PM
MitsuEvo1's Avatar
Update:
Did a boost leak test and found some leakage in the lower IC pipe. Fixed it and ran car.. Still boosting at 15 and dropping to 14. Swapped out stock cat w/ a test pipe, still boosting at 15 and dropping to 14. Since those didn't work, I think I will be trying to see if my actuator is bad... Any other ideas/suggestions if this doesn't work??
Old Mar 17, 2010 | 02:19 PM
SeeCoryRun's Avatar
isnt factory wastegate pressure between 13-15? it is possible they had a mbc installed and removed.... might be missing wategate pill and solinoid connection.
Old Mar 17, 2010 | 02:37 PM
Evo_Jay's Avatar
This is INCORRECT. Boost was not 14lbs on an 04 RS from factory.
Here are the stock boost specs.
03-04 (all models) - 19.5lbs
05-06 (all models) - 20.5
If your seeing 11-14lbs,. then your on wastegate boost and something is wrong with your boost solenoid or other form of boost control (MBC, EBC)
