boosting low
Old Mar 17, 2010 | 04:04 PM
MitsuEvo1's Avatar
Originally Posted by Evo_Kid
This is INCORRECT. Boost was not 14lbs on an 04 RS from factory.
Here are the stock boost specs.
03-04 (all models) - 19.5lbs
05-06 (all models) - 20.5
If your seeing 11-14lbs,. then your on wastegate boost and something is wrong with your boost solenoid or other form of boost control (MBC, EBC)
That's what I thought, so I should swap out my WG/actuator is what your suggesting?
Old Mar 17, 2010 | 05:48 PM
sparky's Avatar
quote=Evo_Kid;8105747]This is INCORRECT. Boost was not 14lbs on an 04 RS from factory.
[/QUOTE]
I can't vouch for all 2004 RS's....just mine. Mine is not USDM, so it probably is not representative of the rest. My RS was ordered as a Latin American Market Evo. We have notoriously lousy pump gas down here(89 octane premium). So, I think that the factory may play it safe with the very few Evos that it ships down here and slightly detune them.
I guess that I should have specified that my car is not a USDM version and thus was not delivered with the same state of tune or standard equiment found on the USDM's. It has a recalibrated JDM ECU. My RS came with the JDM RS TiAl turbocharger w/9.8 HS. It also has a factory Anti-Lag system(ALS), JDM MAP sensor, and an RS "short" close-ratio gearbox that redlines fifth gear at about 125-130 MPH.
I shouldn't have generalized! There was however nothing wrong with the boost solenoid or boost control. In my case the low boost situation was remedied by adjusting the wastegate actuator rod.
Kody Mills
10
May 13, 2017 12:52 AM
proracer718
15
Dec 27, 2009 07:14 AM
evolvingevo
12
Dec 12, 2009 07:59 AM
nonschlont
Nov 23, 2009 03:48 PM
Evojj25
Sep 15, 2009 09:43 PM
