Engine build questions.
Old Mar 24, 2010 | 04:10 AM
Fast Frank's Avatar
Originally Posted by 20gmr
I have seen two oil pumps go that had AMS balance shaft elims in them. One was my personal car and one was a close friends. Its not that AMS peice that casues issues, its timing belt tension and install errors, but they market this piece as *better* for your pump which is totally false. Make sure the tension is setup correctly and remove the gold sprocket on the oil pump to install the new balance shaft, DO NO I repeat DO NOT remove the gear that drives the oil pump. This Thing is UBER tight and the only way to stop it from spinning is to use the balance shaft, doing it this way puts an extreme side load on the drive gear inside the oil pump causing it to gaul into the front case.
Slighlty above and to the right of the timing belt pulley on the front cover you will notice a gold sprocket/cap remove that to access the bolt holding the driven gear of the oil pump to the balance shaft. Once the install is done fill the oil pump with assembly lube.
I would personally recomend the stubby shaft.
It sounds like in your case it was not the race shaft that caused your problem. I have had Mitsu cover a front case housing in the first 12 months of purchase. At least this saved me from purchasing a new front case/oil pump.
The gear your talking about you couldn't remove because it would cause no oil pressure.
Overall just trying to understand your overall justification to stay away from the AMS race shaft....
Old Mar 24, 2010 | 06:46 PM
THUB's Avatar
I think he's saying not to remove it while installing the balance shaft. Having just done this job, along with my own engine build, I can't figure out what the balance shaft bearing would possibly do to stop the oil pump gears grinding into the housing. It doesn't stop the gear from moving front to back in the engine in any way. I can't see it hurting, but I can't see it helping either.
Old Mar 26, 2010 | 11:42 AM
20gmr's Avatar
I was saying to remove the gold sprocket to install the balance shaft/stub shaft. some people remove the timing belt pulley from it then all the screws that hold the pump to the front case to do the install which is incorrect.
The part that fails in the oil pump is the front case, timing belt tension pulls the steel shaft on the drive gear into the case. The balance shaft /stub shaft/race shaft is attached to the driven gear of the pump hence there is no way it provides any *extra* protection for your pump. When I ordered mine I was under the impression the AMS shaft had something on the end of it to prevent the spreading of the gear causing the gears themselves to wear into the housing, this however is not the case nor a common way for the oil pump to fail.
tscompusa
158
Jan 17, 2017 02:52 PM
ridenrunwv
10
Jul 4, 2015 07:29 PM
dsm nexus
12
May 27, 2014 03:12 AM
voidmind
19
May 1, 2012 10:27 AM
Ralliart403
49
Jul 5, 2011 08:16 AM
