Who's running a 2.4L Mivec???
Old Mar 11, 2010 | 09:55 AM
  #31
BLKCarbonEVO's Avatar
Originally Posted by n2oiroc
im building a higher compression (9.8:1 or so) 94mm stroke 4g64 with 156mm rods which gives me a 2.21L with a 1.66 r/s ratio. slapping a twinscroll 4088R on it.
Ya my build is a 10:1.
You are better off to use a 159mm rod w/ the 94mm crank. It would give you a 1.13ch and a 1.7r/s there or about. Also have you looked into the 4094R?
Mikey
Old Mar 11, 2010 | 10:01 AM
  #32
n2oiroc's Avatar
Mikey
i thought about the 159mm rod and its just not worth the extra expense and hassle. aaron from er said he needed a ton of extra machine work to get a 162mm rod to fit and i imagine the 159 would need work too. 1.66 r/s is already pretty good. last i heard, 4094's are laggy and just dont make any power over a 4088. plus i originally was going to use a 35r until i worked out a good trade for the 4088. im not worried about a lack of power, im more worried about breaking drivetrain parts at this point.
Old Mar 11, 2010 | 10:12 AM
  #33
Ya I have broke enough drivetrains parts for the both of us. The 159mm is a fairly easy build. You just grab up a std 1.13ch piston 86.5 or 87mm. The only extra expense would be getting the custom rod made... I don't know if anyone stocks a 159 rod. That would be a good question for Aaron.
Lag, why you worried about lag? Where do you think the 4088 will spool on the 9.8:1 LR2.2?
I think a TS 4094 1.06a/r on a high comp LR2.2 would be pretty sick!
Mikey
Old Mar 11, 2010 | 10:15 AM
  #34
n2oiroc's Avatar
Mikey
with my ported .95 a/r turbine and full-race manifold i would venture a guess of 25 psi @ 4,700 or so in 3rd.
Old Mar 11, 2010 | 11:07 AM
  #35
Ya that sounds about right. You will love the higher comp 2.2! I wanted to do that but it was cheaper to do the LR2.4. I think I'll be really happy with the 2.4 everyone that has one loves it!
Mikey
Old Mar 11, 2010 | 01:04 PM
  #36
JohnBradley's Avatar
I am doing a 9:1 LR2.4 since my car isnt getting raced anywhere but on ramps and my secret closed course lapping days and such I'd rather have even more torque on the street and rev a little lower since I dont like rapping 9400 all the time.
The 2.2 is getting parted and sold to a customer.
Aaron
Old Mar 11, 2010 | 04:57 PM
  #37
SeanC's Avatar
http://www.importtuner.com/tech/impp...ion/index.html
Here is a 4G64 MIVEC build...
Old Mar 11, 2010 | 05:19 PM
  #38
JohnnyTSi's Avatar
Wow! that is a high dollar build! for only targeting 550-600hp
John-
Old Mar 11, 2010 | 06:07 PM
  #39
John-
My build is very close to that but we are putting in much larger bumpsticks
That's a really nice write up though.
Mikey
EVOlutionary
Oct 15, 2017 04:11 PM
doncarbone
10
May 29, 2017 05:20 AM
dambikeracer
25
Sep 14, 2015 10:44 AM
GraphiteEvo9
For Sale - Cars For Sale
Sep 5, 2015 12:09 PM
dan l
Jun 3, 2007 07:06 PM
