Strokers - what cam profile is ideal?
Old Mar 22, 2010 | 05:05 PM
  #61
xRoguex's Avatar
Originally Posted by 3gEclipseTurbo
Can we get a parts list, and a boost graph. it seems the turbo may be to small for your setup and it cant hold the boost to redline, where it actualy starts to fall off at 6k rpm.
Relevent parts include
BR intake
80mm red
BR race fmic
BR 65mm TB
MAP rev2 intake manifold
Kelford 272s
Supertech springs
BR combustion chamber work
BR 2.4 with 9.5-1CR
MAP rev2 exhaust manifold
Megan o2
BR TBE - no cat.
ID1000's with 255 -- 93 octane only.
LC-1 WB
Old Mar 22, 2010 | 06:46 PM
  #62
3gEclipseTurbo's Avatar
A boost log/graph would be nice. Im building my 2.4l now and im still not sure which cams i want to go with. Im thinking kelford 280's as im going with a 6765.
Old Mar 22, 2010 | 07:32 PM
  #63
DaveK's Avatar
I have Tomei Poncams on my 10:1 2.3L stroker. My build was tilted towards mid-range power for pulling out of corners at high altitude. Better spool than most 35r cars in Denver, but I'm sure I sacrifice top end.
Dave
Old Mar 22, 2010 | 07:47 PM
  #64
BLKCarbonEVO's Avatar
Dave
Graph?
Mikey
Old Mar 22, 2010 | 08:15 PM
  #65
JohnBradley's Avatar
7100 is where I would expect a Red to start dying off to be honest. Not sure that cams are the answer as much as more turbo. Johnny's car makes peak power with the Black at 7300rpm using a Magnus cast and S2s. I really need to spend some time with the car on whatever fuel it ends up on (pump or E85) as I think there is definitely more to be had in playing with the MIVEC on the bigger motor vs my standard 2.0 S2 map.
I know on my 2.2 it didnt take much displacement to drop the 3586 from 8330 on the 2.0L to 7800 on the 2.2L. So before you examine cams sometimes the turbo is the first place to look if you are looking for a higher peak power RPM. The thing about that though is the motor really doesnt like to rev well consistently past 8400-8500 before the piston speed is pretty high (8300 is 27.1m/sec mean piston speed).
2.4 arent revvers, they are meant to be stump pullers. We want wider powerbands at more useable rpm levels which is why we switch. The 2.4 is truly a place where you cant have your cake and eat it too. Either enjoy the spool or put a large turbo and get ready to rev the crap out of it. Cams can be used to make more power in a given powerband (lets say 4k-8k) but they wont magically make the power stay higher past a certain point.
Our tech Jake's (currently) stock turbo'd 10:1 2.4 is a prime example. It makes awesome power at 476/495 but the power band is really 3k to 5500 and while it still makes 400whp to 7k it is straight done at 7. Throw a Black or a 67mm on and it might make good power to 7500 or 8k but it will be the same thing again. This car has a worked head and off the shelf S2s right now for the sake of the cam discussion. It will be interesting to test some other cams in it in the near future to see what happens.
Aaron
Old Mar 22, 2010 | 08:20 PM
  #66
DaveK's Avatar
Originally Posted by BLKCarbonEVO
Graph?
Mikey
I don't have a graph of the car on the 35R, but I'm attaching one with the car on AMS' dyno with the TR30R turbo. This turbo is designed for a 34mm restrictor (used on rally cars), but running an open intake tube the size of the turbo inlet, 48mm.
Dave
Old Mar 22, 2010 | 09:09 PM
  #67
xRoguex's Avatar
I plan to pull the red in favor of a black upgrade - upgrade to a 25psi waste gate spring and switch to the BF272's.
The car has plenty of power as it sits for me - I just think with the black I would be able to maintain similar torque levels while still having the ability to conintue climbing in power past 6000 and level off some where more around 7500. I figure based on what most people have been seeing an increase of 40 or so whp is likely for me up top.
I dont plan to rev past 7500 unless its needed for a 4th gear finish.
Old Mar 22, 2010 | 09:51 PM
  #68
So what cams would be ideal for a 6262 or 6765 on a 2.4l? Kelford 280's? With pistons/rods/crank balanced i plan to turn 8k at the track an 7.2-7.5k for dd.
Ted B
Jul 26, 2014 07:08 AM
David Buschur
18
Mar 17, 2012 10:32 PM
3gEclipseTurbo
14
Apr 18, 2010 11:52 PM
Boostin4g63
13
Apr 14, 2008 06:05 PM
04Evo8RS
Aug 15, 2006 05:04 PM
