Dump vs reg. o2 housing on FP Turbos
Old Dec 1, 2011 | 10:39 AM
  #136
High_PSI's Avatar
Originally Posted by Broham
R/T,
Are you saying, there are no 3" 02 housing with 2.25" dumptubes besides your custom one that you made? I have noticed that they are mostly 2.5 with 1.75 dump tube.
That's hwo they originally were. It's hard to fit an 02 Eliminator stright 3.0 inches plus a sizable dump but it has been done. I have two that were custom fabbed. I am going 35R so I wana sell them now.
Old Dec 1, 2011 | 11:33 AM
  #137
R/TErnie's Avatar
R/T,
True,
Most people want to use AC and be able to go between three different LICPs.
Mike's car doesn't have AC and had a MUSE LICP. Pretty easy to fabricate a huge dump tube when you have space.
I'm going to make one for a friend here shortly... It's going to be a 3" turbine discharge with a 2" dump tube on an Fp Black. He's keeping his AC and has a 2.5" (I assume ETS) licp. I'll do my best to make it fit. I'll try and snap some nice pictures to show some of the fabricators here how to do it.
There's no money in making o2 housings, I don't want to make them, and no you can't buy one, so please don't ask. If I can show a fabricator (probably Toxic Fab or MAP) how to make it work then you guys can buy them at cheaper than Walmart prices through active vendors.
Old Dec 1, 2011 | 11:55 AM
  #138
Broham's Avatar
I figured as much about the fitment woes with ac lines and licp. so a 2.5" housing, dumptube to 3" dp, 3" testpipe and 3" catback should be the least restrictive setup, unless you custom fab full 3" and try to make it all fit. Thanks for the response.
High psi, I'm sure you'll find a buyer no prob
Old Dec 1, 2011 | 02:56 PM
  #139
High_PSI's Avatar
I hope so, they are quite rare.
Old Dec 1, 2011 | 03:20 PM
  #140
Erik@MIL.SPEC's Avatar
Originally Posted by pboglio
I don't own an EVO, but I helped my friend switch over from the "Works 3" dumped 02 housing" to a ported Megan. The before and after wasn't conclusive since there was some port work done to the exhaust manifold and turbine housing along with the Megan. The Works expanded out to 3" with a horrible step reduction back down to 2.5" which would cause quite a bit of turbulence. It was a poor design.
I know this is an older post, but I wholeheartedly disagree with the comment regarding the "horrible step reduction." The Works O2 housing is 3" from O2 to downpipe if you have both the DP and the O2. If you don't have both, it essentially defeats the purpose of either. If the OP was talking about the brass adapter for a non-Works DP and the OEM donut gasket, you kinda missed the point of getting both the DP and O2 together.
Oh yeah, it's what Robert runs on his car and uses the same brakcet support on the block that the OEM O2 housing uses as well
Old Jan 6, 2012 | 06:58 PM
  #141
gymnasty's Avatar
I want to purchase an O2 dump and these are my options: Muse, Map, Jmf & ToxicFab so In what order would you guys put theses in from greatest to least. Tia!
Old Jan 6, 2012 | 07:25 PM
  #142
ToxicFab's Avatar
If you have any questions about my o2 dumps, please feel free to shoot me a pm
-Collin
Old Jan 6, 2012 | 07:29 PM
  #143
ToxicFab's Avatar
Originally Posted by R/TErnie
True,
I just built a full 625 inconel o2 dump for my personal car using 2.5" for the down pipe section and a 2 3/8" dump out the hood. I'll have to get pics up. I won't get into the whole 3" v.s. 2.5" part...
Collin
Old Jan 6, 2012 | 07:52 PM
  #144
3K's Avatar
3K
ToxicFab
Old Jan 6, 2012 | 08:00 PM
  #145
gymnasty's Avatar
You have a pm Collin!
Old Jan 6, 2012 | 08:02 PM
  #146
gymnasty's Avatar
Anyone else out there care chine in?
Old Jan 7, 2012 | 09:58 AM
  #147
VRSF Tiago's Avatar
Let me know if you have any questions regarding the Muse dump. We have over 100 of these out in the market and I run them on both our shop evos
Old Jan 7, 2012 | 10:55 AM
  #148
420a-t's Avatar
The JMF is amazing, and fits awesome too.
Old Jan 7, 2012 | 12:04 PM
  #149
Broham's Avatar
what kind of fp black gains can be expected on pump from a dump vs normal o2? 30 # pump? is it worth the loud as hell noise on wot?
Old Jan 8, 2012 | 12:05 AM
  #150
gymnasty's Avatar
Are you 100% sure the fitment is perfect? I read around here that you needed to push the A/C pipe cause it would touch the dump tube. Have you experienced this? How low does the dump tube go? Do you have any pics of it already installed on the car? And last why does yours look the way it does is it a different version then the one online today?
heres a pic see the difference in the dump tubes.
