enough fluid?
Old Apr 2, 2010 | 07:42 AM
sevy2213's Avatar
enough fluid?
hey guys im in the middle of changing tranny fluid and im have read that the tranny needs about 2.7 to 3 qts. is that true for the 6spd also becasue i have put in bout 2.5 qts since i have a 1/2 qrt left over. im jsut tryin to make sure i have enough in there before i go on to something else
thanks for the help
Old Apr 2, 2010 | 08:23 AM
heel2toe's Avatar
Although I dont know how much fluid you will need for the 6 speed id imagine it wouldnt be much different than the 5 speed. You need to keep in mind that it is hard to base the amount off volume as you will not be able to get all of the old fluid out.
With that being said the only sure way to fill it and know that you have enough is by filling it until it starts to ooze out. Also make sure that your car is completely level.
Old Apr 2, 2010 | 08:26 AM
sevy2213's Avatar
yea thats what i did....just plugged it when it started to come out...thanks for the help
Old Apr 2, 2010 | 08:33 AM
heel2toe's Avatar
Well then you should be good to go. Glad I could help
Old Apr 2, 2010 | 09:41 AM
boostedwrx's Avatar
6speed is 2.3 quarts I believe. I usually just start pumping fluid in until it starts running out. Then I'll let it drip for a minute or two until the drips become a few seconds apart. Then I'll take it for a spin and check it again.
R88D_03BBY
Aug 24, 2014 12:21 PM
MyEvoRocksUrv8
Jun 27, 2008 05:20 AM
skred
Apr 1, 2008 02:54 PM
grenade
May 2, 2007 02:59 AM
Kodiak
Apr 26, 2007 03:14 PM
