Hks Sucks?!?!
Old Nov 7, 2003 | 08:57 AM
SidewaysEvo's Avatar
cool thanks for help. so tell me if this will work. 3 inch monster dp or pretty much any three inch dp +3 inch ultimate racing test pipe + hks exhaust. or should i go with a jic exhaust?
Old Nov 7, 2003 | 09:20 AM
BADWRX's Avatar
JIC Titanium baby!
Old Nov 7, 2003 | 01:22 PM
David Buschur's Avatar
Our systems do not use a reducer either. We have done some tests and as the HP gets higher that small reducer will really choke off the flow.
Our full 3" system with the testpipe also does NOT throw a CEL, weigh in at only 24 pounds and costs only $750 in fully mandrel bent 304 stainless steel.
David Buschur
www.buschurracing.com
Old Nov 7, 2003 | 01:26 PM
blonde's Avatar
the monster sports downpipe is NOT 3" just for the record. it is 70mm and for some reason eveybody says it is 3".
Old Nov 7, 2003 | 03:17 PM
EvOLcHiN's Avatar
So since the HKS has a reducer to fit the stock cat, does that mean that if wont fit a 3" high flow cat?
Old Nov 7, 2003 | 03:51 PM
value's Avatar
Better ditch the idea you need a 3" exhaust to make serious HP. Plenty of high HP 500+ without 3" exhausts.
Old Nov 7, 2003 | 04:53 PM
i just want to do it right the first time. i am getting 3inch turbo back. just trying to see what set up will work good with a jic exhaust or hks exhaust. and i just want sumthing that doesn't throw a check light.
Hakmeister
Jan 1, 2013 09:00 PM
coolarrow
10
Jun 15, 2008 09:03 AM
turbo271
23
Oct 31, 2007 01:19 PM
X350ZOwner
23
Jul 18, 2006 02:54 PM
2befast
Oct 6, 2004 11:10 PM
