Any legitimate 4.11 final drive experiences?
Old Apr 9, 2010 | 11:55 AM
  #31
1d10t's Avatar
Apparently no one wants to share. I would like David Buschur to respond. Obviously badbish is not on stock FD, well unless it revs to 12000
Old Mar 8, 2016 | 12:49 PM
  #32
3gturbo's Avatar
Originally Posted by 94AWDcoupe
The 4.11 is a bad idea for most. Dave choose the 4.11 for auto cross reasons. car would spin too much on tight course in first and second with shorter gears. In a straight line car will be quicker with 4.53 in. and even quicker yet with 4.85 which no one seems to consider. The 4.11 does not make car quicker. Its good maybe if you want very low RPM on highway. or want to hit 200mph. otherwise you will be killing some acceleration. I bet 1000$ daves project white would have ET'd lower and trapped higher with 4.53 and shifting to fifth.
I made a thread on this years ago. It might be a good read for you.
https://www.evolutionm.net/forums/dr...shift-5th.html
Its actually a good idea for a stroker engine. The evo 8 1/2 are really low geared already with my car is 2478 cc I believe and 9.8:1 and I run out of gears fast 120 is about 7k.
Old Mar 9, 2016 | 02:10 AM
  #33
Migsubishi's Avatar
I personally ran the 4.11 in two different transmissions, each time the car was faster without it. If I can get to x mph before the same car using a 4.11 but lose some mph shifting to 5th but still be ahead of the 4.11 car winding out 4th I'll take it!!!
A wise man once told me, "To make the car move the quickest it can go, you need to find the shortest gearing you can go with that will still maintain traction".
Kinda miss the old guy...
Old Mar 9, 2016 | 05:37 AM
  #34
3gturbo's Avatar
Originally Posted by R/TErnie
your experience differ from logic and physics... that's why you're wrong.
Ernie that is the same guy that sided with specops motorsports when they ran my car out of gas on the dyno and destroyed it. "It wont rev past 5k were not sure why". Logic doesn't apply to him.
bwanner
38
Jan 10, 2022 11:38 AM
roni4g63
May 29, 2017 11:01 PM
delcster27
11
Mar 29, 2017 03:05 PM
gigitalon
Jan 26, 2017 03:23 AM
mikakatk2
Mar 8, 2016 02:11 PM
