Head leaking oil - need advice
Old Apr 8, 2010 | 08:02 AM
shadow1's Avatar
I installed a Buschur head over a year ago. Runs great but my head gasket is seeping oil. I lost about 1/2 quart over the last 3000 miles. Should I re-torque my ARP head studs? If so, what is the best method to do so? Or should I should leave it alone?
Old Apr 8, 2010 | 08:16 AM
lemmysports2's Avatar
i always re torque mine to 90 ft/lbs after initial startup. let the motor get to its normal operating temp, shut it down, take the valve cover off etc..
heres the sequence...
https://www.evolutionm.net/forums/at...lt.install.png
Old Apr 8, 2010 | 08:21 AM
shadow1's Avatar
Do you loosen and then re-torque the studs to 90?
Old Apr 8, 2010 | 11:09 AM
Murf's Avatar
No do not back them off then torque again.. Follow mitsu's torque sequence, and ARP's torque values of 80 ftlbs. torque in 3 even incraments to the 80lbs. When I torque head bolts I will do one sequence wait 15 min. to allow for any air to escape or the torquing compound to settle. I will do that after each torque cycle. I will retorque after 1K miles. that is just my number. torque when head/block are cool.
Old Apr 12, 2010 | 12:20 PM
20gmr's Avatar
same problem with my buschur head. I am just getting it back together now, i tried some of that permatex copper spray a gasket. I used it on both mating surfaces as well as both sides of the gasket. Then tq'd to 25-50,100. Hopefully that seals her up
Biggy VIII
Aug 9, 2016 03:06 PM
ANCGuy03
Oct 6, 2015 07:41 PM
DIDYSIS
18
Feb 24, 2013 10:14 AM
ilikeppie
10
Dec 25, 2011 09:03 AM
holiday63
Jul 27, 2010 06:53 PM
