Evo 9 output shaft help ASAP!!!!!!!
Old Apr 9, 2010 | 02:10 PM
Nastynine's Avatar
Question Evo 9 output shaft help ASAP!!!!!!!
So I'm dropping my transmission using the evo moto clutch flyeheel install and I came to the part where the output shaft has to be removed with a dent puller.
According to evo moto the output shaft is on the drivers side of the tranny but on my car the output shaft is on the passenger side...
Does it stil have to be removed with the dent puller becaue it won't budge when I try to pull it...
Is this diferent because it's an evo 9?
Does the output shaft still have to come out or can it remain in?
I need help asap please
thanks,
nick
Old Apr 9, 2010 | 02:15 PM
Walt's Avatar
I did my clutch on a evo 9 and it's the drivers side shaft that needs to be pulled not the pass. side. then the transfer case can be pulled out of the way. I tied mine out of the way with wire.
Hope that helps! GL
Old Apr 9, 2010 | 02:19 PM
03lan-evo's Avatar
yeah man driver side or left side whatever...
Old Apr 9, 2010 | 05:22 PM
Nastynine's Avatar
How tho?? The driver side output shaft is resessed into the tranny....?
Old Apr 9, 2010 | 05:51 PM
sho669's Avatar
Thread a bolt into it and use a slide hammer. I made an adapter for mine.
Old Apr 9, 2010 | 06:50 PM
GTijoejoe's Avatar
Me too.... You'll need to use M8X1.0 I believe
Old Apr 10, 2010 | 05:45 AM
Berts24's Avatar
I did it once with out a slide hammer but it's hard to do, a slide hammer makes it really simple
alex3dworld
Evo X How Tos / Installations
84
Apr 21, 2016 08:36 PM
BrunoBoy650
Apr 5, 2013 05:02 PM
Dvolution
Feb 25, 2013 03:07 PM
snafufx
11
Mar 26, 2011 09:00 PM
wazmunstr
23
Jan 30, 2011 06:23 PM
