Best Transmission Fluid for EVO 8
Old Sep 4, 2014 | 01:51 PM
  #76
Ryan.Kauz's Avatar
Per my recent conversation with Jon at TRE regarding a slight grind getting into 5th gear, he made the following reccomendation for transmission fluid:
"While I do offer a recommendation for the Amsoil, I must say that the reports that I receive back are less than perfect.
I would imagine that the oil must be too slippery for the synchronizers to work effectively.
I have been using Motul GEAR 300 and I must say this oil is awesome!
You may want to try it out and see how that works for you."
Based on Jon's input I switched to the Motul GEAR 300 and have been VERY happy with it compared to the Amsoil flushes i've done over the past 1.5 years.
For those who don't know, Jon is one of the premier transmission builders/modifiers in the DSM/Evo group and has been offering transmission/diff builds longer than just about anybody else.
http://www.teamrip.com/Evolution.html
Old Sep 4, 2014 | 02:04 PM
  #77
xXANCHORMONXx's Avatar
I tried redline 85w, cocktail, amsoil, oem and motul.
With my new build I've been going back and forth between oem and motul.
Unfortunately the amsoil did not work for me nor did the redline, 5th gear grind and very notchy.
Motul is notchy when cold, but once you drive it around its awesome.
Oem has always done well for me.
Old Sep 16, 2014 | 04:04 PM
  #78
Ryan.Kauz's Avatar
The GEAR300 i've been using doesn't seem to have any loss in cold drivability.
Old Sep 16, 2014 | 04:09 PM
  #79
e_kobz's Avatar
I just started using Motul Gear 300 oil recently and love it
Old Sep 17, 2014 | 09:47 PM
  #80
jfetty's Avatar
For those with the 5th gear grind, have you installed the BR shifter bushings and underhood bushings? I just did and my 5th gear grind is gone. Just a thought.
Old Sep 18, 2014 | 03:00 PM
  #81
Ryan.Kauz's Avatar
Yes. bushings were installed years before the grind started so I have no direct comparison, just that there is grind and there is bushings.
Old Sep 24, 2014 | 06:05 PM
  #82
Evolution 8 MR's Avatar
Ive been running Motul for almost 2 years now and its been butter! Little rough when cold but when it heats up its super smooth.
Old Oct 3, 2014 | 12:44 PM
  #83
Joey B's Avatar
Veteran: Air Force
I'll be heading the way of Motul 300 as well for a trial.
The amsoil I've been using, since the brand new TRE built tranny, has been notchy in the 1st/2nd shift for a bit (gone through a couple of flushes, and was about to do a 3rd). Extreme cold weather hasn't really been a huge factor for me since I drive mine mostly in the late spring to early fall in warmer weather.
Old Oct 8, 2014 | 11:10 AM
  #84
Ryan.Kauz's Avatar
Don't forget to replace those washers on the drain/fill plug. If memory serves, yours were fairly mashed up last time.
Old Nov 7, 2015 | 01:06 PM
  #85
REDEVO1113's Avatar
After recently just switching from mt 90 to ams oil mtg I have been getting a grind from shifting into 4th. Did not do it before fluid change. It has been doing this ever since fluid has gone in. It only does it at higher rpm shifts, like 4000 and above. I have only put a few hundred miles on fluid, and sometimes it doesn't grind upon first driving it. I'm confused, wonder if I should go back to mt90! Car is a
evo8
Old Oct 18, 2016 | 10:22 PM
  #86
2rbolag's Avatar
I have 3 gallons of unused amsoil synthetic 80w-90 gear lube from a different car. Does anyone have any experience concerning this particular lube for the evo 5 speed tranny?
Ghilversumtuner
Lancer Tranny/Drivetrain Tech
23
Apr 11, 2019 09:28 PM
Lucas Mendoza
Aug 22, 2017 07:01 PM
YzBrad99
31
Jul 16, 2017 05:20 AM
rydogg008
May 23, 2016 03:27 PM
