Exedy twin install need help!!!
Old Apr 24, 2010 | 08:14 PM
mr.almeida's Avatar
Hey guys I'm still stuck on this damn install and I'm really aggrevated right now. Here's the problem...
-Installed a Rebuild Kit
-Bought new Retainer Clip and TOB
-Bought a new floater plate (The big one)
Problem:
When I go to engage the fork it doesn't come out enough for the slave cylinder to touch it. I know the TOB is engaged to the retainer clip because everytime I take off the tranny I have to disengage the retainer clip from the TOB. WTH can be the problem, if anyone can help me out I'd appreciate it. I've pulled the tranny 3 times and no luck.
Old Apr 24, 2010 | 08:45 PM
evoboi005's Avatar
are you trying to say the slave rod doesn't push the clutch fork enough to move the tob?
Old Apr 24, 2010 | 08:47 PM
mr.almeida's Avatar
Yea you can say that. It's like the fork isn't where it should be for the slave to contact it. It's roughly in the middle I'd say.
Old Apr 24, 2010 | 08:51 PM
evoboi005's Avatar
maybe the two springs on the shaft that the fork is mounted on?
Old Apr 24, 2010 | 08:56 PM
binky's Avatar
A few questions:
1) Are you sure all the clutch plates are installed in the correct way?
2) Is your slave cylinder broken?
3) Is your clutch line bled properly?
4) Did one of the spring(s) that hold the clutch fork get messed up?
5) Is the tranny lined up correctly? Did the tranny's splines line up correctly?
Are the bolts from the bell housing to the block tight?
-Bink
mr.almeida's Avatar
Well I replaced the TOB and the fork moves fine, but I'll double check it. I stopped for today, so tomorrow I'll hop back on it.
Old Apr 24, 2010 | 09:04 PM
evoboi005's Avatar
when you push it does it "snap" back when you let go of it ?
Old Apr 24, 2010 | 09:16 PM
mr.almeida's Avatar
Yea it'll snap back. Fork starts in the middle I push it to the driver's side and it goes back to the middle.
Old Apr 24, 2010 | 09:28 PM
mr.almeida's Avatar
Originally Posted by binky
A few questions:
Yes, I downloaded the PDF from Exedy's site.
[/B]
No sir, it was working perfectly fine, just had to rebuild the clutch due to it slipping on the dyno.
Yea I gravity bled it, didn't seem like I had enough pressure though because the fork wasn't close enough to the slave.
No everything's fine.
I only put two bolts on and made sure the dowels were in. Everything's lined up, I press the fork over to make sure the TOB is engaged, but the fork doesn't reach the slave enough to get a good grab.
Where should the fork be? Closer to the driver side or in the middle?
-Bink
Replied
Old Apr 27, 2010 | 09:10 PM
evo8daddy's Avatar
dude lol i bet your slave cyclinder is bad and stuck in position!!!! replace and watch what happens because you should have to push that rod back in order to install it!!!
ptm5070
12
Sep 19, 2014 04:38 PM
marcusE
16
Jun 26, 2013 08:15 PM
EvoRaider
Jan 24, 2013 08:53 AM
dyezak
Oct 26, 2010 11:57 AM
mr.almeida
Apr 19, 2010 10:10 AM
