Twin Scroll Turbos?? Monster Spool.. FACT or FICTION???
Old May 4, 2010 | 06:42 PM
  #181
Geoff Raicer's Avatar
mike - what about the 997? The most advanced gasoline turbocharger i am aware of is on this car, and mfg'd by borgwarner.
i dont doubt you blew up BW turbos, but in our experience we have not had a single customer turbo failure come back to us - not one. FWIW a 360 degree thrust has disadvantages over the 270 degree - the only advantage is more surface area. If you run clean, high viscosity synthetic oil i see no reason why you would wipe these 270 degree thrust washers out.
edit: philthy - good finds, im sorry i can not share some of the documents i have
Old May 4, 2010 | 06:43 PM
  #182
03whitegsr's Avatar
Originally Posted by Ted B
Garrett won't be on the leading edge of the learning curve. It was only fairly recently that they relisted a GT35R as being suitable for something as small as 2.0L. Garrett no longer appears to be a market leader, but is a market follower. How long was it before they actually released a billet compressor unit for general consumption after independents like FP and Precision had multiple examples proven in the field?
I have to disagree with Garrett not being on the leading edge. I simply think that other companies are just on the edge of the marketing front FOR THIS INDUSTRY.
Billet construction doesn't mean **** for what we do. From a performance standpoint, billet construction improves Low-Cycle Failure fatigue life and NOTHING else. We really don't load a turbo in that range, as it would be similar to stop and go traffic hitting full boost almost instantly. Think large diesels that are constantly starting and stopping, like garbage trucks and buses.
Billet construction is more cost effective for producing small batches though, as there isn't the initial investment in tooling required for casting. Because of this, it does allow a manufacturer to go from concept to production quicker. That doesn't mean that concept is any good though.
As for market follower, just an FYI, that billet GTX4294R was designed and produced back in like 2002 from the references I've been able to dig up. Which I beleive is further back then BW or anybody else was offering billet wheels?
Those parties with the most data on TS (e.g. OEMs, racing teams, etc.) are those I see as least likely to make it available to casual enthusiasts.
BINGO which is why I keep asking for references. I'm sure the data is out there, the question is how do you get it?
Old May 4, 2010 | 07:07 PM
  #183
n2oiroc's Avatar
Originally Posted by 4g63smokinall4s
Great comparison Mike!
This is def true.. and my experience with Precision and speaking with them on the phone numerous times they even recommend for the evo running a line as close to the filter as possible for proper oil pressure.. we have decent pressure of the stock location but they still recommend the relocation of the feed line.. and STI's have def have problems with adequate oil pressure for the turbo so it does not suprise me at all he was having problems.. ive ran my precision at 29psi with no problems.. and have rebuilt to have all seals upgraded...
sti's generally run higher oil pressure.
Old May 4, 2010 | 07:09 PM
  #184
spdracerut's Avatar
Argh, I wrote a long reply but it timed-out, so this is abbreviated. The reason there is all the 'billet' wheels out there is because the small companies don't have the resources to tool up to cast a wheel. And 5-axis machining is getting cheap now. Spend $100k to make tooling for one wheel before even making anything? Or spend a $100 bucks machining one. OEMs have the volume where it makes sense financially to cast wheels, small turbo companies do not. And all those small turbo companies are probably just copying OEM wheels and resizing them.
Also, just 'billet' wheels are not any stronger than cast UNLESS the billet they start with is forged. I know the OEMs (Garrett, Borg Warner, MHI, IHI) used forged blanks to start with. The OEMs have been making forged fully machined wheels for quite a while.
As for the GTX wheels, those were designed in 2007 from what I researched.
For data related to twin-scroll, I feel there's enough data out there to logically reason the advantages of it. Reference, BMW N63 and S63 engines. Same basic foundation, 4.4L V8s, direct injection. Differences being open voluted vs. twin-scroll setups. The S63 with twin scroll makes more power, more torque, and more torque at a lower rpm, from bigger turbos.
The fundamental idea of separating cylinders that are next to each other in the firing order for twin-scroll is the same basic idea of NA performance header tuning.
Anyways, I had more written before but gotta run. You can go to the SAE website and try searching for papers with keywords: twin entry, twin scroll, divided.
For the hardcore engine data you want, only the engine manufacturers will have it, and they don't like sharing much!
Old May 4, 2010 | 07:23 PM
  #185
JohnBradley's Avatar
http://www.youtube.com/watch?v=zDWA_4wpobc
This shows 2 advances. I am not tempted by the power of the Twin Scroll side.
BUT
I am tempted to put the TB pre turbo and let the turbo free rev in vacuum between shifts however. I mean it only made 1000whp per liter or so, and 80psi needs something to help it spool. There are SAE papers on this as well. The vacuum on the compressor is nothing new, but I know of ZERO people other than JR and I that have even talked about it. Anyone else?
1980 > most engines in 2010
Old May 4, 2010 | 07:28 PM
  #186
03whitegsr's Avatar
spdracerut, I could be wrong on the GTX stuff. I have a reference from 2002 though where they tested a conventional 6 blade + splitter against an 11 blade compressor wheel in a GT42 based turbo. The turbo was for a garbage truck and the focus of the design was to reduce the induction noise that you get with a splitter blade and ported shroud. The 6 blade wheel was cast, the 11 blade was billet. The billet wheel offered about 10% increase in airflow with similar spool as a secondary benefit.
Maybe it is a different design, but it sure sounded like they were talking about what would later become the GTX42 wheels.
JB, I've been very interested in it. Got a couple references on that topic as well. Actually, the idea that I liked the most was actually a 2 valve system to maximize response. You have a throttle plate on the inlet of the compressor, but then you also have a one way valve that bypasses the TB and turbo/intercooler. The pre-turbo TB stays closed when you first get on the throttle and the air short circuits around the turbo straight into the upper intercooler pipe. The TB before the turbo then gradually feeds in. The net effect is near N/A throttle response and it also reduces the pressure drop of the system when the turbo is not producing boost. As the turbo comes on, the 1-way valve begins closing from the pressure difference and the turbo starts taking over. The controller to pull it off would need to be electric though and you would need to base it off TPS, engine RPM, and turbo shaft speed.
The benefit of the 2 valve system is the single valve helps keep the turbo spinning fast once the speed is already high, on shifts and on-off-on throttle modulation. The 2-valve system helps spool the turbo even when it's been spinning slowly.
Old May 4, 2010 | 07:52 PM
  #187
Ted B's Avatar
Pardon me for not being more clear, 'FOR THIS INDUSTRY' was my point. LOL
You do what I did to get access to Ford EEC-IV programming in the early '90s. You get to know someone on the inside who has access.
Old May 4, 2010 | 08:25 PM
  #188
nothere's Avatar
BUT
don't know if it will help, but there are some pretty pictures, mostly a battle of memories
http://www.efi101.com/forum/viewtopic.php?t=5586
Old May 4, 2010 | 08:55 PM
  #189
spdracerut's Avatar
11-blade, yes. Same blade design? No At least that's what I was told at PRI.
As for putting a valve in front of the compressor.... I'm not really liking that idea. Couple things: first, you need a speed sensor on the turbo to make sure you don't overspin it. Next, by putting a valve in front of the compressor, you're reducing the pressure at the compressor inlet. This, in effect, means the compressor is operating at a higher pressure ratio and can put the compressor into surge at low flow rates.
A modern solution to achieve the same goal is anti-lag or VNT. Anti-lag, not so turbo friendly. VNT... only one turbo on the market designed for gasoline. Of course, compressor surge is horrible for turbos too; it'll destroy the wheels and bearings.
Old May 5, 2010 | 02:48 AM
  #190
leecavturbo's Avatar
OT
i'm surprised the anti lag method of turning the turbo into a mini gas turbine via fuel injection pre turbo hotside didn't take off as it was turbo friendly i.e no pops and bangs
Old May 5, 2010 | 09:29 AM
  #191
spdracerut's Avatar
Ah, the IHI 'Rocket'. I could never find detailed info on exactly how it functioned. The angle that it's welded to the manifold makes it seem like flow goes out, not in. But the only way that it makes sense in how it works is if it injects fuel and air.
Old May 5, 2010 | 12:41 PM
  #192
Porsche and Ferrari played around with it at the same time BMW was making 1500whp. It was originally labelled as Hyper Bar and is talked about in either Turbocharging 101 or Max boost. Bleeds air from the compressor directly, injects fuel/ignites, and uses the turbine as the combustion chamber.
aaron
Old May 6, 2010 | 03:44 PM
  #193
scorke's Avatar
They are "baller" because, thus far, they require two gates and an expensive manifold. But when it comes down to it, the twin entry turbo setups flat out work better.
Quicker spool
Higher Volumetric efficiency throughout the RPM range
Better turbine efficiency
Lower exhaust back pressure
Besides the price tag, what's not to like?
I personally think the way to go about it is a single 60mm gate that has the port for the gate divided and sealed up to the valve. Kind of similar to the STOCK EVO "single flapper" turbo that was developed in rally racing where all out HP is JUST as important as turbo response.
One last little thought here, look at EVERY large frame GT series turbo. See anything in common? All divided entry turbochargers, despite the GT line being built SPECIFICALLY for high performance gasoline engines. Developed for Diesel engines or not, even a company with a multi-billion dollar research and development budget thinks that gas motors should be using the divided inlet turbochargers...
Well, I guess that wasn't my last thought, this is: too much beer makes me happy. "FOCKER OUT!"
03 GSR you said this 3 years ago.... Amazing how time changes things.
Scorke
Old May 6, 2010 | 04:06 PM
  #194
Erik@MIL.SPEC's Avatar
Scorke
Yes, but I think he's looking for hard data. All those are true in theory (and probably application), but no one has done a strict A/B test with limited variables on this platform. That's all he's asking for (I think).
Old May 6, 2010 | 05:21 PM
  #195
I am going to go through my notes and start a separate thread, but from my understanding of the papers it doesnt operate at any pressure ratio since its free revving in vacuum (this can be a shaft speed problem very fast obviously). Its the sudden transition from vacuum back to being a compressor that can be the problem.
