Twin Scroll Turbos?? Monster Spool.. FACT or FICTION???
Here's a 1.06 TS T3 HTA3076R.
https://www.evolutionm.net/forums/ev...e85-33psi.html
Like I said above, a 30R in a 1.06 TS T3 housing doesn't do bad at all.
35R has non business in a TS T3 housing.
I'll be running the EFR7670 in the TS 1.05 A/R T4 housing.
If I ever need to go bigger, I'll just step it up to the EFR8374!
Here is your recipe:
HTA3076 with 1.06 twinscroll T3 on E85 - https://www.evolutionm.net/forums/ev...e85-33psi.html
I'll definitely see what you are up and give you a shout over the next couple days. Your Full Race twin scroll manifold is holding up great!
So my ts .78 on the 3071 is like a ss .47?!?
That's could be why I'm getting surge and power flats out at 6k?
Again. I am liking the searching...
Yes the .78ar ts t3 housing would be restrictive to top end power. Make a new thread with your setup and ailments. I am sure someone can help you figure it out.
The graph below is from my IX with the GTX3076R.
I first ran the T31 4-bolt 0.82 a/r with RevHard cast Manifold (gold line)
I then swapped to the T31 4-bolt 0.63 a/r with RevHard cast manifold and retuned (blue line)
I then swapped to the T4 TwinScroll 1.06 a/r and did not touch the tune. Manifold was my custom made short runner TwinScroll design with dual Tial 38mm's. (green line)
I made slightly overall more power with the 1.06 a/r TS vs. the 0.82 a/r and gained 900rpm in spool.
Thanks!
Do you think it's worth changing the flange to a T4 on a GT3071, or it's the same if I turn to a T3 divided 1.06?
First of all, I would consider a better turbo. A GT3071 does not produce good power for its rate of spool. An HTA3076 or GTX3076 outspools and outperforms a GT3071.
A 1.06 TS T3 is what you need. Drifto is using this, and it supports 600whp with his HTA3076 and E85:
HTA 3076 - 1.06 TS T3 - E85
If one cannot get 600whp out of a 1.06 T3 TS, the turbine housing is not the problem.
Forget trying to change the flange to a T4. This is impractical.
Intended use is AutoX, that's why I choose the 3071, because it's very important for me to have full boost, 2.0l engine, around 35oo rpm not later, and I've always been told that the 3076 is laggier than mine.
About the T4 flange, I thought to cut my current T3 divided flange on my ts manifold and weld a T4 flange, if the T4 1.06 ts was a better turbine housing for the 71, but I'm happy to hear is not necessary to turn to it!
We are not talking about the same thing. A 3076R is laggier than your 3071R, but not by much. An HTA3076 or GTX3076 spools as fast (or faster), and makes much more power. In my opinion, the 3071R does not give very good power for the time required to spool it.
Something to consider.
Ah, I always thought the GTX wheels to give more flow but to be laggier than the corresponding GT...
so GTX 3076 lower max boost rpm than GT3071, and GT3071 lower max boost rpm than GT3076?
Here's my dyno plot
T4 1.00 A/R precision 6265 (will be going to the 66 upgrade next year)
Red Is the baseline
Blue Is as far as we could get before a Walbro started acting up.
Green Is where we left off.
Red Is the baseline
Had some unrelated drivetrain issues that took the car off the road for a whole so I can't remember when i achieve full spool as I'm breaking the transmission and clutch in but its a 2.4
one question guys.
Stock block evo 9
Supporting mod ic,pump,injector,exhaust,t4 twinscorll manifold ecc.
6262 t4 twinscroll 0.84 a/r or 6266 twinscroll t4 1.00 a/r?
will a 6262 vband singlescroll 0.82 spool faster than a 6266 twinscroll t4 1.00 a/r?
No matter about other turbo like bw or garret.. is a simple question about this configuration.
Thanks a lot
target 450 whp and not a super laggy spool, will 0.84 twinscroll 6262 fall hp at high rpm?
Stock block evo 9
Thanks a lot
