Twin Scroll Turbos?? Monster Spool.. FACT or FICTION???
Old Nov 22, 2012 | 01:20 PM
  #256
JohnBradley's Avatar
Originally Posted by JohnBradley
http://www.youtube.com/watch?v=zDWA_4wpobc
This shows 2 advances. I am not tempted by the power of the Twin Scroll side.
BUT
I am tempted to put the TB pre turbo and let the turbo free rev in vacuum between shifts however. I mean it only made 1000whp per liter or so, and 80psi needs something to help it spool. There are SAE papers on this as well. The vacuum on the compressor is nothing new, but I know of ZERO people other than JR and I that have even talked about it. Anyone else?
1980 > most engines in 2010
Its been 2.5 years but I am going to change my mind.
I did some testing recently in addition to what we have learned with Jeff's drag car that leads me to the conclusion I was wrong.
A 1.15 T4 divided built 22.3psi of boost at 4500 vs a 0.82 T3 on the same motor and setup.
Comparing the 1.15 directly to a very similar build albeit with a 0.68 single scroll T4 showed equivalent spool but backpressure problems at high PR on the single scroll vs the twin scroll.
The main issue with people not seeing the results with twin scroll has been mismatched housings to turbos. The SAE paper that said a divided housing spools like its 60% of its size in an equivalent ope scroll is nearly exact.
1.15 x 0.60 = 0.69
It goes on to postulate that the housing can make 90% of the power for its size vs an open scroll.
1.15 x 0.90 = 1.03
Winning.
Aaron
Old Nov 22, 2012 | 01:25 PM
  #257
As far as factual data for response time I will have some in the next few weeks and months as I transition to a larger twin scroll setup on my car. I have a BW S360 with a 0.91 and 1.00 to try and if those arent quite what I want I'll order the 1.10 as well. It is only a 60mm inducer but it has a larger turbine than the 3794 I used last year so I am assuming I can get away with murder even on my large displacement, good VE, 2.4L.
We have also had a few Evos and STIs in lately with large twin scroll setups that I am going to post data from and compare to other cars with similar open scroll kits.
aaron
Old Nov 22, 2012 | 10:05 PM
  #258
03whitegsr's Avatar
If only there were stainless steel twinscroll housings that could hold up better then the diesel cast iron stuff that is available. Even Ni-Resist would be better then what we have access to for the Garretts.
I think a lot of people thought poorly of TS not only because of sizing the hot side incorrectly, but also because there were several using TS turbine housings with open scroll manifolds getting junk results and saying the TS housings suck. There was also guys trying to use one wastegate, either only venting half the motor or teeing the separate runners together and then to the gate. Both of these situations kill the TS effect.
Old Nov 23, 2012 | 09:00 AM
  #259
Ted B's Avatar
The SAE paper that said a divided housing spools like its 60% of its size in an equivalent open scroll is nearly exact.
The basic tenets of twinscroll are exactly that.
It all revolves around the simple concept that a properly sized, more efficient collector design improves torque while minimizing power-robbing turbulence and standing waves simultaneously. It's a longstanding realization in the NA world that applies to turbo applications as well.
Keep us posted.
Old Nov 23, 2012 | 11:56 AM
  #260
Teeing the runners together has been common practice since the last years of turbo F1. I agree that there are better solutions of course. Maybe I should go in the turbine housing casting business
Keep us posted.
The one thing that I am not sure is going to give relevant data is the Auto. I can lock it in gear without a downshift but its propensity to flash to the stall speed for the power level its making might not show the data in the dyno sheet correctly. Since I can do it versus time it might still show what we need. I will rely on the manual cars as much as possible though. On Jeff's car we can see a 2,000 rpm difference between the auto and manual when loaded up as a clutch cant create the load a converter can which directly affects how fast the twin scroll will work to build boost.
aaron
Old Nov 23, 2012 | 02:25 PM
  #261
Drifto's Avatar
If done correctly, merging the paired cylinders does NOT kill the TS effect. The dyno plot from my car linked several times in the thread is a single wastegate TS manifold. As long as the paired cylinders are kept separate right up to the valve, the TS effect is still quite present.
Old Nov 23, 2012 | 02:41 PM
  #262
ETS Michael's Avatar
Holy crap... Someone got the Delorean up to 88mph. This thread is old!
Old Nov 23, 2012 | 04:48 PM
  #263
When I am wrong I like to correct it
Old Nov 24, 2012 | 08:26 PM
  #264
03whitegsr's Avatar
That's not teeing them together, at least not what I mean by it. Your method should work, it's the same premise as the stock housing.
I have to ask, has that divider actually held up? It looks too thin to hold up to the extreme heat it would see in that location.
Old Nov 25, 2012 | 06:23 AM
  #265
Drifto's Avatar
^ Gotcha. I misunderstood your description, and yes, it's very similar to the stk turbine housing in execution. The divider is 16ga. 321 so it should be just fine. It's a new maifold design for me and all of it is 16ga. 321ss. I was going to pull the wg off and check the divider, as it has been on the car for the last 1,500mi. If it were mild steel or 304, the heat would definately make short work of it.
Old Nov 25, 2012 | 06:33 AM
  #266
211Ratsbud's Avatar
I like the throttle infront of the turbo concept. got suggested in a few anti lag threads before.. still just plain neat!
Old Nov 25, 2012 | 07:05 AM
  #267
HMatt's Avatar
Just read the whole thread... Subscribed.
Old Nov 25, 2012 | 08:23 AM
  #268
03whitegsr's Avatar
Drifto, definitely curious as to how that divider holds up. I've been very curious to know if 321 can hold up in that situation or if inconel would be needed. What size gate are you using?
Aaron, something to consider, I think those turbos that use the throttle valve on the turbo inlet have special thrust bearing systems. The vacuum "pulls" on the compressor wheel and if the thrust bearing can't deal with that negative thrust force, it's probably going to cause problems. I can imagine controlling it might be tricky too.
Old Nov 25, 2012 | 08:38 AM
  #269
Drifto's Avatar
The early Buick T-Types had the TB in front of the Turbo, which worked fine as they were non-intercooled. Once you added 6ft of plumbing and I/C to them, the TB was relocated to the more conventional position, as it caused odd laggs in response to the throttle opening. With modern fuel injection, there may be ways to compensate for that.
Old Nov 25, 2012 | 08:41 AM
  #270
Drifto's Avatar
44mm Tial
