Twin Scroll Turbos?? Monster Spool.. FACT or FICTION???
Old Dec 9, 2010 | 07:29 AM
  #226
scorke's Avatar
Originally Posted by supersal
I have had both twin scroll and single scroll, in the absence of any solid data I had to make my choices based on what I could deduce from the haphazard results...
I'm currently on a SS T3 .63 on a 2.3L 4G63
and I would venture to say that it would take a TS T3 1.06 to match the HP output of the SS T3 .63 still on my T3 TS headers...
and the transient response of the T3 .63 is pretty good, I don’t believe a T3 1.06 on the same manifold can spool any quicker or offer significantly better transient response, or make any more power...
Well at least that’s the conclusion I came to after playing with this stuff for the last 3 years... Initially I thought that a TS T3 .78 was equivalent to the T3 .63 but I'm not so sure anymore...
If I had to choose between a HTA35R with a T3 .63 or a TS T3 1.06 I would choose the T3 .63 given my experience I feel you trade top end power for low end and transient response with a Twin Scroll...
regards
Sal
Sal a t3 .63 and a t3 divided 1.06 are nowhere near similarly sized housings for the same engine configuration.
I went from a t3 .63 to a t4 1.06 and didn't lose power or tq anywhere in the revrange.
Sam
Old Dec 9, 2010 | 08:22 AM
  #227
Philthy748's Avatar
Originally Posted by ronshearer
I don't keep up here much anymore. The last I knew however. The so called "professionals" haven't done any R&D or ever produced any solid data endorsing their marketing campaign. I'd bet more research went into how to market their new product than the actual development of it. Reminds of some of the crap you see for sale on late night TV or the Home Shopping Network.
There is plenty of real world road racing results to support TS superiority over SS - Now, if you're only holding you foot down for 8, 9, 10 seconds and using a ~1500rpm power band, doesn't matter much I guess... But, when you're actually driving on the street or road racing and moving your foot up and down, TS is far superior over SS...
I have had several 'SS is King' people in my EVO, and they all left with the same dejected look on their faces... How can a big turbo make all that power and still be so responsive and fun to drive, TS - that's how!
Old Dec 9, 2010 | 01:16 PM
  #228
supersal's Avatar
Sam
OK thanks Sam, like said I've retained my T3 Twin Scroll Manifold,
So for my next turbo I may go to a HTA35R or a FS635 with the T3 1.06 TS and see how it compares to my T3 .63 6262. (rest of my setup will stay the same)
hope its worth the extra money...
Sal
Old Dec 9, 2010 | 01:17 PM
  #229
scorke's Avatar
Sal
To really make the twin scroll worthwhile go to a t4 divided. The size of the 1.06 T3 is going to start to hurt when you go that big in turbo.
Find something with the same wastegate flanges to save some money!! It will be well worth it.
Sam
Old Dec 12, 2010 | 10:41 PM
  #230
Strm Trpr's Avatar
30R's do pretty well in a 1.06 TS T3 housing.
35R's have no business in a TS T3 housing.
A 35R with a TS 1.06 T3 will have similar topend performance as a SS 0.63 A/R T3.
1.06 * 0.6 = 0.64
Curt Brown thru down 811whp with a SS 0.82 A/R T3 housing on a HTA3586R.
An equivalent TS T3 housing that has the same volume as a SS 0.82 A/R T3 housing would have to be 1.37 A/R TS housing.
0.82 / 0.6 = 1.37
Old Dec 13, 2010 | 07:42 AM
  #231
juanmedina's Avatar
Mike should just buy a TS setup and test it vs his single scroll kit and be done with this stupid discussion. No one is proving a direct comparison, and data to back their claims. Mike just do a back to back to test, prove that TS doesn't work or become a believer it would be good for the community
Old Dec 14, 2010 | 08:23 AM
  #232
38six's Avatar
It's to much $$$... In the after market world, TS is still in its infancy stage... As technology improves there will be more introductions of TS turbos that can be used for a straight up comparison. Look at the new EFR BW turbos, its just a matter of time...
Old Dec 14, 2010 | 09:56 AM
  #233
juanmedina's Avatar
Mike has the resources to do the test
Old Dec 14, 2010 | 10:27 AM
  #234
Erik@MIL.SPEC's Avatar
That's true. They didn't go to SEMA to unveil their new single scroll turbo series
Old Dec 14, 2010 | 10:47 AM
  #235
supersal's Avatar
1.06 * 0.6 = 0.64
0.82 / 0.6 = 1.37
Valuble Info! Thanks.
Old Dec 24, 2010 | 09:23 AM
  #236
ceegutta's Avatar
Originally Posted by Steve93Talon
Garrett released native .82 and 1.06 divided T3 hotsides for 30r and 35r turbos a few months ago:
http://www.atpturbo.com/mm5/merchant...egory_Code=GTH
We're running a BW S362 on a DSM in a divided T3 .85ar hotside, seeing 38psi by 5k and making 700+whp. Another friend is running the same turbo/mani setup with a .76 div. T3 housing and seeing 24psi at 4100 rpms. Both cars on 2.0 bottom ends. For comparison, another local with an S362 running a 2.3 engine and open T3 hotside sees full boost just over 5k and made 691whp.
Steve I gotta call u about the TS mani's for my DSM. I'm convinced right there!
Sam
Steve Talon in his post above is making very gd pwr using a T3 TS mani so I don't understand?
1.06 * 0.6 = 0.64
0.82 / 0.6 = 1.37
Steve must be doing something right then with his divided T3 TS mani,700whp with a .85 divided housing with a T3 looks pretty damn gd to me.
I understand TS is the way to go but with the T3,T4 thing Im a lil confused.
Old Jan 24, 2011 | 11:13 AM
  #237
Hiboost's Avatar
I really did try and read all the previous pages but is there a consensus of what would spool better with the new GTX3076R wheel? From what I would gather I should look at a T4 1.06 A/R Twinscroll vs a T3 .63 A/R Single with 1.25" runners and a goal of 600-650 crank HP. This car will be a daily driver and used for road racing where response time and spool is highly disireable.
Currently I have the Garrett Evo X kit that spools the regular GT3076R at 20 psi in 4th gear by 3600 RPM. It's a .94 A/R Twinscroll that has essentially lost the twinscroll benefit since I'm using an ATP O2 DP with Tial 44mm WG to fix the broken internal WG failure. Unfortunately there is no divider leading right up to the Tial WG but I could weld one in to see if suddenly it gained 300 rpm of spool?
I find the ball bearing responsiveness of the combo works quite well, and if I can have STM make a custom T4 1.06 A/R twinscroll setup with a GTX3076R and 1.25" runners I think it would do really well.
Any thoughts?
Old Jan 24, 2011 | 11:24 AM
  #238
Strm Trpr's Avatar
Here's a 1.06 TS T3 HTA3076R.
https://www.evolutionm.net/forums/ev...e85-33psi.html
Like I said above, a 30R in a 1.06 TS T3 housing doesn't do bad at all.
35R has non business in a TS T3 housing.
I'll be running the EFR7670 in the TS 1.05 A/R T4 housing.
If I ever need to go bigger, I'll just step it up to the EFR8374!
Old Jan 24, 2011 | 11:25 AM
  #239
Ted B's Avatar
Here is your recipe:
HTA3076 with 1.06 twinscroll T3 on E85 - https://www.evolutionm.net/forums/ev...e85-33psi.html
Old Jan 24, 2011 | 05:03 PM
  #240
Geoff Raicer's Avatar
hey chris - its been a while since we spoke. we're working on some cool stuff for the Evo X, i think you will be interested
