EVO IX not starting after cam install, yet everything checks out.
I couldn't find the hole to check the oil pump, but I also didn't look that hard considering It never moved in relation to the crank. I made sure it was lined up when I put everything back together.
if the marks line up, it has to be right, doesn't it? Unless the internal assembly turns at a different rate than the belt pulley?
**edit: my intake and exhaust CAS sensors were backward. swapped them and that cut my knock counts in half. i'll keep ya'll posted.
heel2toe
46
Mar 24, 2015 04:17 PM
Ev1LEv0
61
Aug 15, 2011 04:04 PM
