car overheats under boost...
Old May 20, 2010 | 06:19 AM
evo4life400's Avatar
i do have ARP headstuds but do i really have to buy a whole nother set of them?i have only had them on for probably 5k miles....i must have torqued them wrong when i was doing the 1X1 method.
Old May 20, 2010 | 05:58 PM
i talked to my tuner and he said he will look to see if he saved my data. would i be able to get the data if i buy a tactrix cable and download ecuflash?
Old May 20, 2010 | 06:37 PM
turbotalawd's Avatar
No you do not need to buy new headstuds you can reuse those.
Doing the 1x1 method might be why your headgasket is blown.
Old May 20, 2010 | 08:36 PM
i hope its not the head gasket...im trying to sort this sh*t out but its not going well...
Old May 20, 2010 | 10:00 PM
EvolNinja's Avatar
For proper tune, you'll need wideband, boost controller and boost gauge. Hope you get the problem fixed. GL
Old May 21, 2010 | 09:01 AM
barneyb's Avatar
i dont have a wideband but both of the tuners said the AFR's were on the money. the fan is all hooked up and i do see it go on when i turn the air on and stuff....i am going to try and get the logs from my tuner...hopefully he will send them to me!
I'd suggest, to see if the fan is actually operating, idle the engine and hang around the engine compartment until you see the fan on without AC.
Old May 21, 2010 | 02:11 PM
i actually noticed that the fan doesnt turn on without the A/C on.....ill look at it again but i did notice that it doesn't go on when its idling....it must go on when im driving without the AC on or wouldnt my car overheat?
Old May 22, 2010 | 08:22 AM
a_awdgsx's Avatar
most like your head gasket, when you change it out arp headstuss!
Old May 24, 2010 | 02:19 PM
barneyb's Avatar
Well, drive it until warm then park and idle - the fan should kick on within a minute for two. If it doesn't, something is wrong with the fan.
CT9A PR
Nov 6, 2014 10:56 AM
jaredh
Mar 26, 2013 04:22 PM
deadstockkpomp
Jul 8, 2012 03:06 PM
Heezayx
Dec 12, 2011 06:07 AM
Evokid03
Mar 21, 2010 01:24 PM
