How much voltage should the injectors be getting?
Old May 20, 2010 | 11:07 AM
3gEclipseTurbo's Avatar
I used a dmm and the injectors are only getting 5.7-5.8volts with the key on, the battery is at 12.2. So shouldnt they be getting 12.2volts or right around there?
Old May 20, 2010 | 11:21 AM
javicracer's Avatar
no they dont get 12 v. I dont remeber if is the 5v range or 6 tho.
Old May 20, 2010 | 11:27 AM
20gmr's Avatar
most sensors operate on 0-5v scale. obviously not all but most. Any reason you are testing voltages at injectors?
Old May 20, 2010 | 11:41 AM
My injector scalings are almost double what others have them set for and the car still idles lean. I boost leak tested and there doesnt seem to be a boost leak, but im gonna double check today.
Old May 20, 2010 | 11:43 AM
willitas34's Avatar
5V reference, so what others stated.
Old May 20, 2010 | 12:00 PM
RSMike's Avatar
why do the injectors only get 5v and not 12v?
Old May 20, 2010 | 12:19 PM
Thats what i dont get. I mean why then do we dial in injectors using volts from 4-18v?
Old May 20, 2010 | 01:59 PM
RSMike's Avatar
i'm 95% sure that the stock injectors are 12v driven with the earth switching via the ecu.
if it was 5v they would never open and if they did it would have massive deadtimes and latencies...
if you're only getting 5v, i would check the voltage on your output relay.
If thats 12v at the relay, maybe your capacitors are blow or partially shorted out etc
mrfred
Feb 26, 2022 06:16 PM
mrfred
Sep 17, 2017 06:11 AM
1091x
Jul 10, 2016 01:19 PM
Wertigo
Oct 11, 2015 01:57 PM
scheides
Mar 6, 2014 08:09 AM
