Tha Dark Knight Evo 8.5 Project
Thank you. The more evidence I get the better. The dumbass adjuster tried to tell me that they couldnt find any used parts or aftermarket body parts for an evo. Lets just say I asked to speak with a senior adjuster who wasnt full of ****. They say i have over $8500 worth of damage. I mean yeah sure if you buy everything from Mitsubishi and have the whole car repainted.
Your best bet is to get aftermarket hood and hid headlights.
hood: http://www.trademotion.com/partlocat...layCatalogid=0 - $920 stock evo hood
Evo 8 Stock Front Bumper: http://www.trademotion.com/partlocat...layCatalogid=0 - $232.50
Evo 8 Crash Bar : http://www.trademotion.com/partlocat...layCatalogid=0 -$206.67
Evo 8 HID Headlight Assembly : http://www.trademotion.com/partlocat...layCatalogid=0 -Right side $978.13 Left Side $822.61
Hope this helps man!
That's interesting, since Progressive is paying for quite a bit of stuff on my car right now. Facepalm on those springs and $6500 for a non-built block from Lancershop though.
Car is back from the shop almost 2 months later. Looks amazing!
Almost totaled out at just over 12k worth of repairs, but I was able to add value since I provided Progressive with a receipt for the motor. Looks like that ridiculously expensive stock motor wasn't that big of a waste.
Unfortunately the body shop ordered and installed an Evo 9 wide tank ETS Intercooler instead of the original Evo 8. Looks like **** and im in the process of trying to get them order the proper one and eat the cost. After all it was their mistake.
I have a fully ported Titek V1 O2 housing and a Walbro 255 awaiting install in addition to the Shepard Tranny sitting in the garage. Still need to get a hold of a set of 850cc injectors, AEM Uego, hi flow cat, FP waste gate, and a Hallman manual boost controller. Going to have a 23 psi tune on 93 at either MZM or Cobbs new facility here in Austin.
This summer I will be purchasing the following:
FP Black Ported
Aem Tru Boost
Kelford, or GSC cams
Supertech Valve springs and retainers
Buschur Ported and Jet Coated Manifold
Buschur Ported Intake Manifold
Tein Flex
Enkei NTO3+M 18x9.5 +27 Powder Coated Top Secret Gold
Tires uncertain
10mm spacers front, rolled in rear.
Power Slot Rotors front and rear
Hawk Pads
32 psi tune on 93
The goal is to maintain the stock block and ECU while breaking through 430 awhp on a Mustang Dyno. I am open to constructive criticism regarding the mods as I am attempting to maintain stock internals.
Pictures to come
FP Black Ported
Aem Tru Boost
Tein Flex
Tires uncertain
Hawk Pads
32 psi tune on 93
Pictures to come
I have a 2003 evo 8 getting a 9 motor now. What did you do about the rear O2 sensor? The plugs on my 8 & 9 harness are different.
Also the two extra yellow plugs and one blue plug under the dash are for the acd correct?
Thanks,
John
Thanks,
John
I purchased an Evo IX o2 sensor for $35 off someone on here. I have also heard that your can hard wire the VIII o2 pigtail to the IX harness and it works perfectly.
Yes the yellow plugs are for the ACD system. As well as the extra plugs near the intake at what would be the reservoir and pump. You can simply delete these at both ends or just hide them like Ive done.
Hope this helps. Good luck with your swap
I was curious what kind of a warranty you got on that there evo 9 crate motor???
edit: 12 month 12k miles lol my bad
Sorry you got scammed BTW...
And I have never had a complaint against progressive, not one whatsoever.
As far as Progressive is concerned, they actually stepped up and payed out alot to have the car fixed. It was a very stressful situation but I got to keep my car and have it repaired back to its original state before the accident. Basically every part on the front clip was replaced to brand new OEM crash catalog, excluding the radiator and intercooler. Car looks brand new and im very happy even though ive had such bad luck.
Cant wait to get that Shep Tranny out of my garage and under the hood
Car is now for sale due to financial reasons. Asking 18,000 obo
Motor has a little over 8k on it so far.
Includes a Shep Trans REM Process 5 speed still sitting in the box!
Will post in 'for sale' accordingly when time permits.
PM if interested
PM if interested
