Tha Dark Knight Evo 8.5 Project
Old May 24, 2010 | 11:55 AM
vince_w2004's Avatar
Feb 13, 2010 I finally bought a 2003 Evo VIII. The car appeared to be in great condition with 75k on it. After going through the car and doing basic maintenance items ie. Spark plugs, oil change, tranny oil change, etc. I noticed that the coolant was orange! Figured some a-hole decided to cheap out and run tap water. So I flushed the coolant system two times. Finally after the second time I was still noticing some sediment in the over flow tank. I figured one last time would be enough. Well it was enough! Enough to clear out all the head gasket sealant that some a-hole poured into the coolant system to hide the blown head gasket. Took the car over to MZM and had a coolant system pressure test done and a leak down check done to confirm what I already knew. Blown head gasket!
Not to bad.....but it gets worse! After removing the head and checking all the specs on the short block, it was found that the cylinder walls were warped on all four cylinders from top to bottom. Not only do I need head work but now I might as well have the short block rebuilt.
Well i was on a budget of about $6500. So what did I do....
Brand New in Box Evolution IX MR Crate Motor Purchased from Lancer Shop shipped to the door for $6100
Evo IX ECU $100
Evo IX Complete Wiring Harness $250
New OEM Throwout Bearing $75
New OEM IX Heater Hose kit $40
Used Evo IX Rear o2 sensor $40 (still not here)
New Mishimoto Aluminum Radiator w/ Gates Hoses $275
New Tein S-Tech Springs $145 (This S stands for '****TY')
K yea I know im already over my budget....thank God for my new Paypal Matercard lol
Old May 24, 2010 | 12:04 PM
XBoost's Avatar
So fresh and so clean!
FL_SilverEvo8's Avatar
Is this a stock motor or built one? For that amount of money I hope it is built.
Old May 24, 2010 | 12:09 PM
munster87's Avatar
Originally Posted by fl_silverevo8
is this a stock motor or built one? For that amount of money i hope it is built.
x2
Old May 24, 2010 | 12:16 PM
binky's Avatar
Originally Posted by munster87
x2
No, it's not built. This is a stock motor.
PS - sweet new motor
-Bink
Old May 24, 2010 | 12:18 PM
Stock but may I remind that it came with both manifolds, a brand new clutch kit, brand new evo IX turbo, all the ignition, everything brand new! Direct from Mitsubishi Japan never turned over.
Since I wanted a Evo IX anyway, I wasnt about to waste my time fixing my VIII long block for more then it would cost to have a brand new IX platform to build from.
Plus my old head was junk and so I would have needed to find a core as well.
Old May 24, 2010 | 12:26 PM
JakeTheVIII's Avatar
Great job on the car Vince, it looks great... I wanna check it out sometime
Old May 24, 2010 | 12:29 PM
K well I was goin to wait but here she is:
meld's Avatar
You bought that car in dallas didn't you?
Old May 24, 2010 | 12:30 PM
igo4bmx's Avatar
sucks there is a special $4995 for the evo9 motors now.
Old May 24, 2010 | 12:33 PM
Yes I bought it at Auto Wei in Carrollton TX. Im currently suing them under the Texas Deceptive Trade Act.
And these motors were once $4995 but have since gone up do to the limited supply.
Old May 24, 2010 | 12:44 PM
Thanks Jake! Still no spark tho....
Be nice to have you come by this week sometime and take a look
Old May 24, 2010 | 01:20 PM
rico91stang's Avatar
Ouch!
Old May 24, 2010 | 01:23 PM
check all your wire harness plugs. some of them won't let the car start. what did you do with the evo 8 valve cover?
Old May 24, 2010 | 01:24 PM
And yes....it is a 6 speed MR Engine code bolted to a 5 speed tranny. And I kept the 6 speed clutch set up. I mean, why not? The MR OEM clutch is better anyway.
