Valvoline VR1 20w-50 Race Oil?
VR1 is very good oil, I know several pro teams that use it and swear by it... the only down side is changes every 1k miles or less... I've been using Pennzoil Racing oil lately and changing oil every 2k... 12 quarts is only $41.59 and it's a really good product...
PENNZOILŽ GT PERFORMANCEŽ RACING OIL is designed for the lubrication of high-performance competition engines. It is fortified with superior additives and oils which resist breakdown under the high loads, temperatures and speeds experienced by fast revving engines.
PENNZOILŽ GT PERFORMANCEŽ RACING OIL is compounded to be compatible with a variety of competition fuels including gasoline, methanol, nitromethane and diesel fuels. It can be used in engines that are turbocharged or supercharged as well as naturally aspirated.
PENNZOILŽ GT PERFORMANCEŽ RACING OIL protects cylinder walls, pistons, bearings and valve train components beyond the levels of conventional passenger car oils. Friction reducing agents incorporated into the formulation assure that maximum horsepower is obtained from the engine
VR-1 i am using too! It works perfectly on my built motor.
I want to try Brad Penn at some point too, but the Valvoline i can find easily, whereas Brad Penn i will have to order online...
Mike
Mike
The reasoning is because you don't just use any weight oil on a built motor.. Depending on your clearances you know what oil to recommend.. Also when you have been building motors for so long you know what WORKS so why recommend something that you dont know how well it works.. Sure I have run Amsoil 15-50 dominator in my Buschur Motors and it has been fine but for warranty reasons he recommends running what he KNOWS works..
Mike
Mike
Buschur, if you can chime in that'd be great. Thanks
