Valvoline VR1 20w-50 Race Oil?
Anyone use this oil? A local race shop the specializes in turbo v8's told me to run this. He said as long as I keep up with the oil changes every 2500-3000miles its better than running a full synthetic, just that ill have to let the car warm up longer as its a thicker oil. As this oil is made for high rpm and heat fluctuation from running high hp and boost. I figured Id give it a try. Thoughts?
Synthetic oils have superior thermal stability, which is especially important to engines that deliver high specific output (e.g. turbo engines). There are no advantages to using conventional oils (aside from price), only disadvantages.
Bottom of the page, the valvoline used whats the VR1 which is stated in a few posts after the one with the test.
https://www.evolutionm.net/forums/ev...il-best-3.html
We have used this oil when we are short Brad Penn and it has always worked very well.. We change the oil on built motor more often though.. Also on E85 we change the oil much more often also..
Mike
Mike
For cars running E-85, I ready by the engineers at Mobil 1 said that Diesel Oil is the best to run because of the high level of detergents. So I run the the Amsoil HDD 5w-30, it's closer to a 10w-40. You might look into it:
http://www.amsoil.com/storefront/hdd.aspx
BR told me to always use the Brad Penn 20W50 in my 2.1. I just sent the first oil change on the new setup away for oil analysis. We'll see how it goes. I have heard nothing but good things about the Brad Penn Green oil...
Mike
Yeah, he told me to use Valvoline or Brad Penn. I didn't want to wait for my oil to get to me so I bought the Valvoline from Advanced Auto Parts. I'm going to try to start using Brad Penn though.
i love it when a mechanic says, ! yeah your ok driving with a broken axle boost for a few months ! you maybe and you maby not if you find out that your axle came off the cup and now the tire doesnt turn.
that why i love data because data show this mechanic to be a liar, synthetics are proven to have many more advantages over dyno oil these days this topic is a no brainer.
...which just goes to show you why you cannot believe everything you're told.
