Blown headgasket or something else?
Old May 30, 2010 | 04:26 PM
awd2gen's Avatar
So pretty sure I blew the headgasket a week after the car was finished. Everything seemed fine, I got on the highway, floored it, hit about 5 to 6k and PPSSHH water all over windshield. Just looking for other possibilities...
Old May 30, 2010 | 04:39 PM
ak47po's Avatar
Mods, work done so on and so on.
Old May 30, 2010 | 04:56 PM
AWD Motorsports's Avatar
Either head lifted badly.. or a water hose burst from pressure due to lifted head.. If you cant find the source of the water spray its probably from the head.. Sorry to hear of the trouble.. Let me know if i can help at all..
Mike
Old May 30, 2010 | 08:56 PM
awd2gen's Avatar
Thanks mike. Are you going to be in the shop Monday? I'll give you a call if you are.
Old May 30, 2010 | 10:39 PM
Fourced4cyl's Avatar
Sounds like a hose came off. Chase the coolant hoses. Could have been the heater core or TB coolant lines.
Old May 30, 2010 | 10:42 PM
EVIL_EV0's Avatar
Check your oil to see if it looks like chocolate milk.
Do a compression test.
Old May 30, 2010 | 10:53 PM
JordanS4's Avatar
Check your freezeplugs too
Old May 31, 2010 | 12:31 AM
awd2gen's Avatar
Thanks for the info. All will be checked in the am when i get off work. Didnt even want to look at it as soon as it happen.
Old May 31, 2010 | 06:36 AM
Liqquid's Avatar
This... seems to be an outbreak of freeze plugs lately... yesterday the one on the driver's side end popped out on mine, sprayed a little bit of coolant on the windshiled as well. It's hard to see cause it's kinda hiding under the thermostat... if you can't find any hoses off get a flashlight and start checking these
Old May 31, 2010 | 11:46 AM
awd2gen's Avatar
Ok so afte looking further found out it is a freeZe plug. One center front on block. How should I go about fixing this?
Old May 31, 2010 | 09:46 PM
awd2gen's Avatar
will have it fixed tomorrow. thanks for the help.
Old Jun 1, 2010 | 12:28 AM
JC evo1's Avatar
whats the reason the freeze plug blew though, you may still have a lifted head.
Old Jun 1, 2010 | 08:55 AM
That is correct.. in 3 years i havent seen a freeze plug pop.. Do a leakdown test to be safe..
Mike
RSMike
10
Nov 15, 2019 09:04 PM
Phoenix*
Oct 20, 2015 09:36 AM
DanDan1320
Oct 10, 2013 06:57 AM
DIDYSIS
18
Feb 24, 2013 10:14 AM
scheides
May 5, 2010 10:43 PM
