Service life of a Walbro pump?
Old May 30, 2010 | 10:12 PM
RSMike's Avatar
Originally Posted by n2oiroc
not exactly a drop in, but im pretty sure an 040 could fit in tank.
does the 040 flow the same amount as the Walbro 255 hp?
edit - answer my own question
http://www.boschfuelpumps.com/
Bosch 040 Fuel Pump Specs:
Bosch Part Number: 0 580 254 040
Minimum Current: 12 Volts
Operating Pressure: 94 PSI (6.5 Bar)
Minimum Flow @ Outlet: 80 GPH (300 LPH)
Fuel Pump Location: In Tank
High Temperature Reduction: 8 GPH (30 LPH)
Weight: 930 Grams (2.05 Pounds)
edit2
Specifications:
Part Number: 0580254040
Flow: 235LPH
Voltage: 13.5V
Current: 13A
Weight: 930 Grams
Mounts: In Tank
Intake Side: M18 x 1.5
Pressure Side: M12 x 1.5
Electrical: Positive M6 / Negative M5
way different numbers to the first website >.<
Old May 31, 2010 | 12:19 AM
Boostd4's Avatar
I've had Walbro pumps in all 3 of my Evos...I can't say that they don't work well. Given that you've gotten 5 years out of the first, you have definitely gotten your money's worth. Just pop a new one in there and you won't need to worry at all.
Old May 31, 2010 | 12:45 AM
riceball777's Avatar
wow should i be worried? Mine is over 5 years old and has about 80k miles on it. I would thing fuel pumps is not something your supose to change on a reguilay basics.
Old May 31, 2010 | 07:14 AM
mrboost05's Avatar
fuel pumps go out in cars all the time people like to run there tank low alot and as you no the fuel cools the pump so thats one quick way to wear them out its cheap insurance man this is a performance car do you really want your fuel pump to go out during a pull on the dyno or at the track.
Old May 31, 2010 | 11:56 AM
a_awdgsx's Avatar
it really depends how much hard you drive and how low you let your gas get before filling up. But after 5 years spending 80 bucks for a new one wont hurt
Old May 31, 2010 | 12:12 PM
Erik@MIL.SPEC's Avatar
That's what I figured
scheides
218
Sep 6, 2013 07:39 PM
car_nut15
Sep 1, 2013 08:55 AM
steven121
Feb 2, 2013 05:30 AM
Evoleader88
May 25, 2010 06:12 PM
anton406
Jan 18, 2010 06:31 AM
