engine lost power at track..car cut off
Old May 30, 2010 | 07:56 PM
sharkm87's Avatar
Unhappy engine lost power at track..car cut off
was at track when it happened..had a great 1st and second run..
third run engine lost power between 2nd n 3rd gears...
so i figure a IC pipe bust off...but all were fine...
looked under car..seen no leaks
visual inspection everyting was fine...
oil n coolant all looked fine
checked the plugs ..cyl 2 gap was shut on the plug..
regapped and car started but heard a light rattle in the motor..couldn't tell if its in motor or was comin from turbo..
after checkin plugs again though to run compression test cyl 1 was closed shut...
compression showed 145ish psi on cyl 1 and 2..and 180psi on 3 and 4...
will have to pull head to see what kinda damage is done...not sure what it could be yet.
Old May 30, 2010 | 08:02 PM
inf0's Avatar
u might have jumped timing.
Old May 30, 2010 | 08:08 PM
buchnerj's Avatar
Take off the top timing belt cover. Take a look at the timing marks and see how the belt looks and how the marks line up. I agree in pulling the head. I would not run it until you rule out valve damage and take a look at how the piston top looks. You could boroscope the motor to check it out if you don't want to completely pull the head off...
Old May 30, 2010 | 08:14 PM
brokeazzlos's Avatar
do a leakdown test.
if timing was off compression would not be that high
Old May 30, 2010 | 08:20 PM
sharkm87's Avatar
thx for all the advice..will be tryin all those things tomorrow..
luckily this is not my dd....
pulling the plug though on cyl 2 you can see some residue on top of piston...looks kinda black n spotty like oil..while the others look clean like bare metal...
i think i'll try and get my hand on the boroscope though..but idk who is opening tomorrow beind a holiday
Old May 30, 2010 | 10:47 PM
EVIL_EV0's Avatar
The last three motors that just "stopped running" at the track were rod bearings.
Drain the oil.
Old May 31, 2010 | 05:24 AM
sharkm87's Avatar
What will i see?
Old May 31, 2010 | 06:35 AM
sharkm87's Avatar
checked the timing...even though i have -4/-1 on the gam gears...TDC dont seem to be lined up with the valve cover....
Old May 31, 2010 | 06:37 AM
sharkm87's Avatar
also how much play should be in the timing belt
Old May 31, 2010 | 10:00 AM
EVIL_EV0's Avatar
My belt moves about 1/4 inch and seems very tight.
If you killed a rod bearing there will be metal flakes in the oil.
Pull the spark plugs and shine a light down on the piston top. If you skipped timing and had valve to piston contact you'll probably be able to see the damage.
Old May 31, 2010 | 05:45 PM
sharkm87's Avatar
Drained oil and there is no metal in it...
Will pull oil pan tomorrow
Old May 31, 2010 | 07:02 PM
Jeff_Jeske's Avatar
I'm not sure I would pull the oil pan yet. I would pull the plugs and do a compression test first.
Old May 31, 2010 | 07:16 PM
sharkm87's Avatar
i did the compression test....piston 1 and 2 showed 145 psi...pistons 3 and 4 showed 180 psi
Old May 31, 2010 | 07:17 PM
buchnerj's Avatar
I would be more worried about inspecting the head than the oil pan. Just low compression in two cylinders stinks of skipped timing with valve damage. Did you do the oil trick? If you do and the compression doesn't rise, pull the head off.
Old May 31, 2010 | 07:24 PM
sharkm87's Avatar
gonna pull the head hopefully this week after i get my hands on a timin belt tensioner tool..haven't seen a write up to pull head but figure i'll follow one to change cams
